Which gauges should I add
Old Aug 8, 2017 | 01:28 PM
Haulinbass02's Avatar
Haulinbass02
Our new to us Ex should be on its way in the next day or so. I'm wondering what gauges I should add to it? EGT and boost are the givens but what else is highly important to be monitoring? Fuel pressure or EOT?
I'm a little old school and am going to do a triple pillar pod unless I can be convinced to go with a Livewire or something like that.
Old Aug 8, 2017 | 04:31 PM
hwybee22's Avatar
hwybee22
$35...obd2 and the torque pro app
Old Aug 8, 2017 | 04:49 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
EGT and boost for sure (Ex's don't have boost in the dash right?), maybe fuel pressure to complete your column three pack. There's no sending unit for EGT or FP, so no wasted money adding those gauges.
Everything else through the digital box. IMO it's too cost prohibitive to add all the 2" gauges you'd need compared to <$50 for an app and dongle. Most things you watch on the digital box like ECT, EOT, trans temp, voltages, those things are important to get baselines on and track on occasion, but unless you're towing aren't something that bears watching constantly. Sometimes it's nice to be able to put the gauges away and just drive the truck. It's a light duty pickup, not an airplane, IMO every trip doesn't need to feel like I'm flying a 747.
Old Aug 9, 2017 | 09:15 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Scan Gauge II - FICM voltage, EOT, ECT, BOOST (if you don't have a OEM) EGT requires your own temp probe in exhaust manifold. Battery voltage. Many others avail for your preference.
Old Aug 9, 2017 | 09:43 AM
texastech_diesel
Token Redneck
Scan Gauge is $157 on Amazon right now.... and it does less than the $5 Torque App.
Face it, it's overpriced and bordering on obsolescence with the proliferation of smartphones and tablets. It's actually cheaper to buy dedicated a 7" Android tablet plus Torque plus the bluetooth dongle than an SGII.
SGII is not cheap. Doesn't scan codes basically at all. Only shows four PIDS at once. Only shows numerical readouts. No data logging. No way to expand. Looks terrible, like an old Ti-83. Have to cycle through PIDs with multiple button presses. The only benefit I can think of is that it's so janky looking that it might not get stolen when you leave it in the truck full time.
Old Aug 9, 2017 | 09:59 AM
Idahoser's Avatar
Idahoser
Yeah, times have changed, there was a time when ScanGauge was the right answer, but if you already have a smart phone it's just a given you need to get a cheap ELM327 and Torque Pro (or whatever it is for apples, DashBoss maybe) without even having to think about it. More money gets you nothing over this capability, unless you're adding sensors for EGT and fuel press.
Old Aug 9, 2017 | 04:37 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
For you guys with young eyes the Torque app may be the answer....BUT....
I can SEE the SG.... and I don't wanna pay a ticket for holding a phone up to my face!
Old Aug 9, 2017 | 10:23 PM
Haulinbass02
Found an ELM327 wifi/Bluetooth adapter, looking to find an old 7" Android tablet of some kind to use. Torque Pro is an Android only thing, the iOS equivalent isn't AS proven so I hate to buy it and it use it. I can find a galaxy tablet for very little on fleabay.
The only thing is, for fuel pressure and EGT I'll have to use analog gauges due to lack of stock sensors am I correct? How is boost calculated? Is it actual pressure or calculated based on other readings? I may still add gauge pod for those basic three and use the Torque App for diagnosis as needed....
Old Aug 10, 2017 | 04:01 AM
bismic's Avatar
bismic
Diesel_Dirk
Aug 26, 2009 06:43 AM
Billyclub
May 12, 2009 03:31 PM
davidcam
Nov 2, 2007 04:21 PM
thetentfactory
Sep 20, 2007 11:18 AM
