Cab lights
Old Aug 1, 2017 | 12:26 AM
Karlow's Avatar
Karlow
Cab lights
I just looked up my trucks VIN.
It has drivers sides door activated dome light with auto delayed off.
It does not work. I can turn the dome light on or off manually, but that's it.
Anyone have a clue whats wrong with it? There is a time delay something somewhere. Any ideas?
Old Aug 1, 2017 | 06:56 AM
Walleye Hunter's Avatar
Walleye Hunter
I'd start with the switch. What's the passenger's side door do? I do not know if it sets the delay function or not.
Old Aug 1, 2017 | 12:09 PM
Karlow's Avatar
Karlow
The code indicates drivers side activation. I can only get them to turn on by using the switch on the light. The truck will detect when you open the door. If the key is in the ignition, so the switch seems to work. I'm not sure where it is located.
Old Aug 1, 2017 | 04:45 PM
Colorado350's Avatar
Colorado350
Pull the bulb, use a meter to see if have power when the door opens, when you turn up dash lights etc. Check for corrosion or solder missing.
Old Aug 1, 2017 | 04:55 PM
Karlow's Avatar
Karlow
It's not a bulb issue. I can turn on the light with the switch on the light. It never turns on when you open the doors. It's just dark unless you manual use the switch. Does anyone know anything about the delay circuit? Do you have a wiring diagram?
woopud
2004 - 2008 F150
Nov 3, 2018 06:28 PM
Derrrrick
15
Feb 6, 2017 01:56 PM
bluecobra
1997 - 2003 F150
Feb 29, 2016 10:17 AM
Wisconsinford
Mar 19, 2014 08:31 PM
Glenn Graham
2004 - 2008 F150
Jun 1, 2009 10:20 PM
