Another issue I'm having is the dome and cargo lights not working right, dome light won't come on at all when opening any door. When i open a door with the truck running it gives me the chime. I can turn the map lights on by tapping them and the rear dome light by moving the switch. Using the dimmer switch the lights won't work either. I can't imagine it's the door switches since it will chime when opening them when the engine is running. Also, when i open the door the odometer will light up. Anyone has any ideas? Could it be the dimmer switch?
