dome light
Old May 31, 2009 | 05:53 AM
Glenn Graham's Avatar
Glenn Graham
dome light
my dome lights won't come on when you open the doors,also no buzzer or door ajar message.all fuses are good,it seems like someone has unhooked the buzzer but i can't find it.
Old May 31, 2009 | 05:59 AM
wildcard30's Avatar
wildcard30
It may be the door switches. Although I seems kinda strange that both would go out.
Old May 31, 2009 | 12:29 PM
Horse Doctor's Avatar
Horse Doctor
Does the dome light come on when you manually turn it on with the switch that brightens the dash lights?
Old Jun 1, 2009 | 07:26 PM
Glenn Graham
the dome lights work manually and will come on when you shut the truck off for 10 seconds or so.the trucks a 4 door so i doubt 4 door switches would go bad.any other suggestions?
Old Jun 1, 2009 | 10:20 PM
Oldguy4's Avatar
Oldguy4
I'm not sure about this, but check you owners manual about the dome lights. It could be that there is a way to disable them from comming on when the door opens and you will need to reverse that. Hope this was some help.
