Overhead display replacement
Old Jul 30, 2017 | 12:14 PM
BillyBob69's Avatar
BillyBob69
99 F350 with the typical dim display on the overhead. I ah e resoldered the chips back down and it did help for awhile but I have ignored it for the last year or so. Well now it is dime again. Took it out to check my works from years ago and noticed a burn mark at the top left of the display. My soldering job still holding so I cleaned off solder and tried again. No go. So it seems the display itself is the issue.
I found some links in this forum but most don't work. So... where can I find a replacement that is REASONABLE in cost? I have found them from$200 on up to just over 400. Not a chance.
I know years ago I found some site that sold them for about $100. Anyon eoknow of a site?
Just the shorty overhead. Temp and compass
Thanks all!
Old Jul 30, 2017 | 01:14 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Got my repaired by a guy on eBay like this one:
Ford Compass Temperature Overhead Console Display REPAIR SERVICE READ DESCRPTION | eBay
Old Jul 30, 2017 | 01:24 PM
BillyBob69's Avatar
BillyBob69
Originally Posted by Whitey Ford
I will have to message them on mine. Tho corner of the display looks burnt. My not be repairable.
Old Jul 31, 2017 | 12:49 AM
Dirtscooter250's Avatar
Dirtscooter250
All of mine have a burn mark at the corner of the display. Does the resistor still test good?
Old Jul 31, 2017 | 07:57 AM
BillyBob69's Avatar
BillyBob69
Which resistor? And how man Ohms should it show?
Old Jul 31, 2017 | 08:26 AM
countrycar's Avatar
countrycar
Here's acouple of places that repair the over head console.
DIGITAL DISPLAY REPAIR Archives - ASAP Speedo - Speedometer Repair - ABS Module Repair
FORD F-series Overhead console kits and Parts
Old Jul 31, 2017 | 03:02 PM
Dirtscooter250
There are quite a numberof resistors on the pcb. The ones that fall off of mine are 690 and I had one that stopped working. If they ohm out ok then time to send into repair facility.
Old Aug 1, 2017 | 07:22 AM
BillyBob69's Avatar
BillyBob69
If I remember mine are all labeled 680 and 620. Tough to ohm them out properly when still attached to the board and hate to in-solder them just to check. May have to hit the local pick-n-pull and see if I can get lucky.
BillyBob69
16
Feb 18, 2016 11:02 AM
Mkozyn
Electrical Systems/Wiring
Jul 10, 2014 06:17 PM
Big Sage
17
Oct 1, 2006 03:02 PM
Jay94250
Apr 27, 2006 05:30 AM
sphinx
Dec 27, 2005 11:51 AM
