The Case of The Mystery Transmission
Old 07-21-2017, 04:55 PM
AmericanDreamer's Avatar
AmericanDreamer
AmericanDreamer is offline
Hello! I am SO excited to be here!
I am the proud owner of a 1966 F-100. In the past year of ownership I've learned that nothing much more than the paint is original. (The engine is a '72 240 L6, for one.) But a previous owner also swapped out the original manual transmission for an automatic. The tricky part is, I was left without a dipstick, and have no clue what size would properly fit! Right now, the transmission is leaking and I'm not sure how much fluid to put in, but would like to figure out what exactly I have before moving forward with fluids, gaskets, filters, O-Ring, etc.
What I DO know:
-The pan has 14 bolts
-11" by 8.5"
-I am finding nothing like "C4" or "FX" on the pan
-Attached is a metal tag that reads (photo)
PHA A289 6J15B
but I was told this tag is for an engine and has nothing to do with the transmission/was put there by mistake?
-A local transmission shop owner kindly looked at it and told me it was a "Cast Iton Small Case 4."
Again, anything helps! This transmission deserparately needs work and I can't begin without a proper identification!
Last edited by AmericanDreamer; 07-21-2017 at 05:00 PM. Reason: Posted accidentally before finishing!
Old 07-21-2017, 05:44 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
Tell the trans shop they have no clue lol. The PHA trans are FX FMX MX family transmissions. The only listing i can find for PHA-A is an FX trans from a 67 or 68 289. Number Dummy I imagine will along soon and be able to identify the application it is out of.
Old 07-22-2017, 12:51 AM
AmericanDreamer
Thanks Matthew! I talked to that same trans shop guy today and he said when it comes to buying the proper dipstick, it only matters whether or not the housing bolts into the case or the pan. Apparently I'll be scoping junkyards for "a small or medium case." Aye aye aye.
Old 07-22-2017, 07:25 AM
ihcc104's Avatar
ihcc104
ihcc104 is offline
Welcome to FTE! Good luck on the truck. Sounds like you will inevitably find more and more mysteries as you dive deeper! I am not much help with the trans, but we would love to see some pics of the truck! The more pics the better
Old 07-22-2017, 09:01 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by AmericanDreamer
1966 F100. The engine is a '72 240 I-6. But a previous owner also swapped out the original manual transmission for an automatic.
PHA A / 289 6J15
A local transmission shop owner kindly looked at it and told me it was a "Cast Iron Small Case FX Cruise-O-Matic."
PHA-A = 1967 Galaxie/LTD 240 I-6/289 V8 FX Cruise-O-Matic (14 trans pan bolt holes).
6J15 = Transmission assembled September (J) 15, 1966 (6).
C6AZ-7A020-C .. A/T Dipstick - 23 1/2" long / Obsolete
1966/68 Galaxie/LTD 240 I-6/289 FX / 1966/67 Galaxie/LTD 352/390 MX / 1966/67 Thunderbird 390 MX // 1965/67 F100/350 352 MX / 1965/72 F350 240/300 I-6 MX
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
Note: MX uses a different pan, pan gasket and filter than FX
C6AZ-7A228-C .. A/T Dipstick Tube - 24 1/2" long / Obsolete
1966/68 Galaxie/LTD 289 FX / 1968 Galaxie/LTD 302 FX
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
87034-S94 .. Dipstick Tube O-Ring / Available from Ford
Ford-O-Matic/FX/FMX/MX Cruise-O-Matic/C3/C4/C6/AOD
Old 07-22-2017, 02:29 PM
F-ONE's Avatar
F-ONE
F-ONE is offline
Personally I cant think of a worse transmission behind a 240 except for the early 60s 2 speeds or the oddball C5 and C3. Now the FX..FMX Cruiso family was tough and OK behind high HP engines. AlsoI do believe that FX FMX MX Cruisomatic family is the basis of the AOD.
These transmissions were designed for heavy sedans with higher HP engines so they rob some power from a low HP engine like the 240.
The C4 would be a much better transmission for you. The C4 is efficient (one of the most efficient of all automatics) parts are readily available and it can be built really strong.
It's something to consider since this one leaks and the prior installation may be less than ideal.
Another option is a later AOD if you want overdrive.
Now you may can repair it and not have to deal with a swap and all the trouble that is, but before I sunk too much money into it I would consider other options.
Old 07-22-2017, 10:37 PM
matthewq4b's Avatar
matthewq4b
The FX and specifically built for lower HP applications. The MX was used for higher HP applications.
The FMX uses the MX internals inside the dimensionally smaller FX Case. The FX has lower parasitic losses than the FMX or the MX of the FX MX FMX family it is best the of the bunch in this application.
The C5 was just a C4 with a lock up torque converter and the C3 is light duty small car (IE pinto) transmission. Neither of which I would call oddball.
All the FX MX FMX transmissions are good stout tranny's Just be sure to use type F Transmission fluid in them and NOT Dexon/Mercon using Dexron or Mercon in a Transmission that is spec'd for Type F fluid is sure fire way to crater the transmission.
Matthew
Old 07-22-2017, 11:37 PM
AmericanDreamer
I'm learning so much! Thanks you guys! I've ordered a new dipstick and housing tube- but is there a known distance from the end of the dipstick to the "full" line so I can make do with a dipstick I already have? Or an amount of fluid that the tranny needs after I flush it? Up until two weeks ago his tuck was my daily driver, so I'd like it back on the road while I wait for the parts to arrive!
dodgens
05-31-2016 12:27 PM
stanz
03-29-2005 11:17 PM
foot947
01-31-2005 10:02 PM
Stanger02
08-10-2002 05:29 PM
JOHH
03-07-2000 10:11 PM
Quick Reply: The Case of The Mystery Transmission
