2006 Ford e350 no start no codes.
Old Jul 12, 2017 | 10:45 AM
Kurtlin Mckibbin's Avatar
Kurtlin Mckibbin
I have this 6.0l that wont start. It stalled going down the road. It'll crank but won't start. I'm out of ideas and any help is appreciated. It'll probably be towed to the dealer soon. Here is where i've gotten so far.
Batteries are only a couple months and have been charged and tested individually and are good.
RPMs- 190 ish
Fuel pressure is 57 PSI ( it passed the Bubble test also)
Both filters are new.
ICP voltage is 1.90 at 1500 PSI
IPR is 85% when cranking. has been replaced during testing because of damage to the screen and crap inside of it. ( brought the pressure up to 1800 PSI)
Inj timing is 7 Degrees.
FICM V is battery voltage
FICM L is battery voltage
FICM M is 48/ 47.5 on the scanner. ( i checked it while cranking at the test port at the back, also passed)
FICM Sync is a yes (Also i've tried a used one).
Sync is a yes.
Intake is drawing lots of air, on occasion the van does try to fire.
Each injector has been individually unplugged, and i tried starting the vehicle in case they shorted the FICM
I've also unplugged the glow plug control modual, Exhaust back pressure and mass air.
I've vissible looked over the injector harness for chaffing and there is none.
If anyone has any insight it would be appreciated.
Old Jul 12, 2017 | 12:28 PM
WatsonR's Avatar
WatsonR
What does fuel pulse width indicate?
1.9v at ICP is good for 1520psi.
What does VREF indicate?
Is the fan clutch plug good and snug?
Old Jul 12, 2017 | 01:13 PM
bismic's Avatar
bismic
Also:
What are you using as a code reader?
Is the fuel bowl filling up quickly (pull secondary fuel filter and turn key on without cranking)?
Do you have a spare FICM to try (or can you borrow one)?
Old Jul 12, 2017 | 02:13 PM
Kurtlin Mckibbin
Originally Posted by bismic
Also:
Its a snap on ethos plus. with the 2015 updates. ya the fuel bowl fills quickly.
I forgot to mention that i replaced both filters, because i cut the old ones open to inspect for junk. they where clean.
I new where there was a van that had been ran hot and siezed so i did try that FICM.
Old Jul 12, 2017 | 02:51 PM
bismic's Avatar
bismic
As Randy asked - v-reference voltage?
Reset the inertia switch?
Does it have a security system?
Checked compression?
Old Jul 12, 2017 | 04:09 PM
Kurtlin Mckibbin
Inertia switch is reset, it doesn't have a security system. compression hasn't been checked but it stalled as if you shut the key off, doesn't sound like low compression when being cranked.
i have my 5v refrence
Old Jul 12, 2017 | 04:24 PM
bismic's Avatar
bismic
How about oil level? Right level and not overfilled? No diesel smell to the oil?
Also, when unplugging things and trying to start, did you try with unplugged EGR valve and ICP sensor also?
Getting exhaust smoke when cranking and it "tries to start"?
Old Jul 12, 2017 | 08:47 PM
WatsonR's Avatar
WatsonR
Check the reading for pulse width... it will fire if it's giving fuel as long as everything else is good. No fuel commanded, most likely a sensor issue is holding it up. If it is commanding fuel, then that's a different path.
You've checked lots of stuff... but not to see if it's commanding fuel.
Old Jul 13, 2017 | 12:19 PM
m-chan68's Avatar
m-chan68
RPMs- 190 ish
Sync is a yes.
Replace your IPR valve in order to verify a known good IPR valve would be the first step. On an E-Series van, access to it is way easier than a pickup.
95Salttruck
Mar 5, 2019 11:55 AM
sunuvabug
Mar 30, 2015 06:55 PM
flcracker9
Mar 3, 2013 07:13 AM
mudslingur
Dec 9, 2010 08:59 PM
watermanh
Dec 22, 2005 12:42 AM
