Cam ID
Old Sep 5, 2003 | 06:55 PM
xericx's Avatar
xericx
Cam ID
Well I picked up a load of FE parts for my truck and with it I got a cam that I am try to ID. The parts of out of an old drag car and all are supposed to be ford castings. The only casting numbers I can find are a X-TA toward the rear of the cam after the last lobe and the number 5 cast on either side of the center journal, if any can help ID the cam or tell me where the casting #'s are supposed too be would be greatly appretiated.
Old Sep 5, 2003 | 08:12 PM
DuckRyder's Avatar
DuckRyder
Cam ID
is there any colored stripe on it?
Old Sep 5, 2003 | 08:26 PM
xericx's Avatar
xericx
Cam ID
Yeah, a greyish color covering about 3 lobes of the cam toward the center.
Old Sep 5, 2003 | 08:40 PM
DuckRyder's Avatar
DuckRyder
Cam ID
X-TA isn't in my book
The only thing that sounds close is 'light blue" both sides of #3 Journal. That is a 390GT/428CJ
Most are marked between dist gear and first journal or between the last lobe and last journal.
Most seem to include an upside down "A"
Old Sep 8, 2003 | 07:27 PM
xericx's Avatar
xericx
Cam ID
Well I looked at the cam where you said and found nothing but grinder marks. Could this be some sort of experimental cam, I mean with the x in the Xta, with the numbers ground off so it couldnbt be id'ed?
Old Sep 11, 2003 | 08:20 PM
DuckRyder's Avatar
DuckRyder
Cam ID
I'm not very sure,
There are certainly people here that have better refrence material than me.
Problem is, there is really no telling what "light blue" would look like after 35 years?
You might try posting this on some of the mustang forums too...........
russrobbins
Mar 3, 2007 03:42 PM
highboy390fe
15
Jan 10, 2006 05:13 PM
Polkat
Nov 11, 2005 07:30 PM
79blueoval
Jun 23, 2004 09:53 PM
lvmoose007
13
Apr 25, 2004 05:54 PM
