Mercon V in E4OD
Old Mar 30, 2025 | 11:17 AM
  #61
Forrest Stejskal's Avatar
Forrest Stejskal
4wd Low
Originally Posted by JJF20
X2 on the engine stand. Makes life a lot easier.
super look good and easy
i have 3 but full of mercedes engines in deposit
Old Mar 30, 2025 | 06:18 PM
  #62
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The numbers cast into the case indicate which die molded that case.
Old Mar 30, 2025 | 06:26 PM
  #63
R&RFord's Avatar
R&RFord
I have been very happy with Mobile 1 synthetic atf 112980.
Old Apr 8, 2025 | 12:48 AM
  #64
Forrest Stejskal
4wd Low
yesterday im finished after 20h work alone change trans but when i ride 2-3 miles and need stop with D trans want go and engine shutoff i thing than problem is in solenoidpack maybe
Fluid is now mercon V
Old Apr 8, 2025 | 11:33 AM
  #65
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Forrest Stejskal
my friends use in aod trans more years atf d2
this is my first Ford and automat but no fwd drive only revers 2 times i change fluid grey dirt on pan without metal . Solenoid when i shift click, control with multimeter ok, valve body all pistons and springs moving right.
I buy another E4od seller from germany say cold shift good but hot move every time (Sorry my English) he use atf type f
500miles around me was only this one for sale
So which valve body did you use? Your original or the one from the transmission you just bought?
Old Apr 8, 2025 | 11:49 AM
  #66
Forrest Stejskal
4wd Low
The What i bought
Old Apr 8, 2025 | 01:31 PM
  #67
Mark Kovalsky
If it is a solenoid body problem you'll have codes for bad solenoids. Are there?
This problem can also be caused by low trans fluid or a missing internal filter.
Old Apr 8, 2025 | 02:12 PM
  #68
Forrest Stejskal
4wd Low
soo fluid level o.k. 9 miles on new merconV i buy 20liter (over 5gal) and in trans is over 4gal fluid on crossed mark i hold break every shift 5sec return to parking with running engine and on stick level ok
I have old model 1990 with analog counter
you mean this filter ?
i have second problem with furl separátor diesel filter original not possible buy our partshop have alternative but nobody know tomorow i buy 3 type 100$
This small filter ?
This small filter ?
I have old analog without display on obd blick cídě 23 and 26
Old Apr 8, 2025 | 02:17 PM
  #69
Forrest Stejskal
4wd Low
Thanks all for help and patience with me
i live in town with small streets more crosseoad and traffic lights is very big problem ride this truck with problems .
Old Apr 8, 2025 | 06:24 PM
  #70
Mark Kovalsky
No, I meant the filter in the pan.
Old Apr 8, 2025 | 11:32 PM
  #71
Forrest Stejskal
4wd Low
yes is new and long for 4x4
92 Red F150
Aug 11, 2010 09:22 PM
FordF350Baby
20
Nov 4, 2008 02:18 PM
FordGP
Feb 9, 2008 10:45 PM
sigtauenus
Apr 21, 2007 09:31 PM
rirwin
Dec 12, 2004 10:06 AM
