Scanner tools on OBS psd.
Old Jun 28, 2017 | 02:31 PM
Rudi's Avatar
Rudi
I have a 1995 F350 dually extended cab with 7.3 PSD.. Does anyone know of a scanner tool that will work for this truck? Standard OBD tools do not work. I have a check eng light that I can seem to chase down.
Old Jun 28, 2017 | 03:28 PM
madpogue's Avatar
madpogue
Do you have an Android device and/or Windows laptop/netbook/notebook?
Old Jun 28, 2017 | 11:09 PM
DrMario's Avatar
DrMario
Vgate Bluetooth scan tool from Amazon works for me I got my codes off it for a bad shunt. Comes with gauge display for your phone too that helps me since my dashboard lights are burned out. Project for another day.
Otherwise AutoEnginuity for way more money but I hear it's amazing.
EDIT addon - I have a CA 97 OBS so it should work on your 97
Old Jun 29, 2017 | 01:28 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
He has a '95.
If it's an early model '95 there's not going to be a lot of OBD help as they are not OBD II.
Late '95 started with OBD II.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jun 29, 2017 | 02:12 PM
madpogue's Avatar
madpogue
If it's ever been to a dealer, it's probably been flashed to use the data port in the cab.
Old Jun 29, 2017 | 03:21 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I have heard about that, but also heard the PCM's in those trucks didn't communicate that way, even though the data-link wiring is in place.
Soooo...Not sure what you say.
__________________
Old Jun 29, 2017 | 03:40 PM
madpogue's Avatar
madpogue
I know I've seen posts from people with '94.5s and early '95s, their PCMs have been flashed sometime over the years, and they are able to use AeroForce, AutoEnginuity, etc. We have two '95s, one was built in March, and I've gotten AE, AF and Forscan to work on both.
Old Jun 29, 2017 | 09:38 PM
knottyrope's Avatar
knottyrope
Not sure what PCM I have but truck is early 95, built in January and V Gate Bluetooth works well.
Old Jul 4, 2017 | 08:52 PM
mcali2's Avatar
mcali2
what app do you use? i cant get mine to work. I have the same blue scanner.
Old Jul 11, 2017 | 02:32 PM
HermannF350's Avatar
HermannF350
I can't get ECU access with my ELM327 + Torque app on my 96' PSD either..
Old Jul 11, 2017 | 02:55 PM
knottyrope's Avatar
knottyrope
scanner to monitor your engine
Amazon Amazon
Torque Pro
https://play.google.com/store/apps/d...g.prowl.torque
Use the communication in the profile
SAE J1850-PWM
make sure you add in Ford PIDs
https://play.google.com/store/apps/d...ch.CarGaugePro
people like it cause it will pull codes, buzz test and CCT
Old Jul 11, 2017 | 03:00 PM
HermannF350
https://www.amazon.com/Vgate-Bluetoo...rds=vgate+OBD2
Torque Pro
SAE J1850-PWM
So it has to be the Torque Pro version?
Old Jul 11, 2017 | 05:53 PM
knottyrope's Avatar
knottyrope
I never tried the free one.
I thought it was cheap enough to buy.
I have used it on 4 different vehicles now and it can save multi profiles too. Very handy app IMO
bvmbandit
May 27, 2012 03:36 PM
DadNSonF350
Nov 22, 2009 09:43 AM
wood-ranch
Mar 29, 2005 09:07 PM
gotama
Oct 20, 2004 01:33 PM
RENAGADE66
Aug 7, 2002 12:32 PM
