What type of scanner would I use for my 1995 F350 7.3 PSD? OBDII is 1996 and newer right? Does it really matter isn't all Powerstrokes 94.5 thru 97 the same?
No I am looking for a device that ya'll are using to uncover some of the more complicated problems you help us with on here. Do these also show EGT's and things like that?
I have a Scanguage from Terminator Engineering in my 95. It's an electronic guage that plugs into your OBD connector and gives you access to all the important sensor readings plus allows you to add additional inputs if you want. It will read and clear codes and perform injector diagnostic tests. I think they are about $250 or so. I like that it is always there and I can watch sensor readings and then I know what's "normal", should help when I do develop a problem down the road.
