Fuel Filter Help
Old Jun 25, 2017 | 02:19 PM
bikerman2299's Avatar
bikerman2299
Fuel Filter Help
Afternoon everyone,
I am looking for a bit of help. I have a 11 F350. I am looking for the connector tube that installs on the engine mounted fuel filter inlet side. Between the fuel line and fuel filter. It has a small barb fitting on the bottom. Mine has disintegrated during routine maintenance. I've been looking through all the different online part sources and cannot seem to find the correct part number. Everything I have been finding is the wrong part.
Thanks in advance.
J
Old Jun 25, 2017 | 06:15 PM
m-chan68's Avatar
m-chan68
Is it BC3Z-9A564-B by any chance? This would be the return hose assembly from the secondary fuel filter to all eight injectors. The plastic tends to brittle and break if excessive force is used, to disconnect the connectors.
Old Jun 25, 2017 | 06:35 PM
bikerman2299
The piece on the end would be it. Thanks! I removed it from the secondary filter to replace the filter and the small hose barb crumbled in my hand. But my truck does have almost 200K on it.
Old Jun 28, 2017 | 12:35 PM
crock's Avatar
crock
Barb
I had the same problem, had to go to dealer and buy the hose with the end lock Sorry for your troubles
Bob C
waggdr
6.7L Power Stroke Diesel
18
Jun 12, 2021 07:56 AM
Kruse
1997 - 2003 F150
Mar 23, 2011 05:14 PM
msk59
1997 - 2003 F150
16
Sep 17, 2010 10:49 PM
ed2hess
Mar 27, 2006 12:45 PM
jeepin
Jul 5, 2003 03:07 AM
