Fuel Filter Help
Afternoon everyone,
I am looking for a bit of help. I have a 11 F350. I am looking for the connector tube that installs on the engine mounted fuel filter inlet side. Between the fuel line and fuel filter. It has a small barb fitting on the bottom. Mine has disintegrated during routine maintenance. I've been looking through all the different online part sources and cannot seem to find the correct part number. Everything I have been finding is the wrong part. Thanks in advance. J |
Is it BC3Z-9A564-B by any chance? This would be the return hose assembly from the secondary fuel filter to all eight injectors. The plastic tends to brittle and break if excessive force is used, to disconnect the connectors.
The piece on the end would be it. Thanks! I removed it from the secondary filter to replace the filter and the small hose barb crumbled in my hand. But my truck does have almost 200K on it.
Barb
I had the same problem, had to go to dealer and buy the hose with the end lock Sorry for your troubles
Bob C |
