Push Button 4X4 won't engage
Old Nov 19, 2001 | 10:27 AM
tobins's Avatar
tobins
93' F150 XLT 5.8L extended cab 4X4 automatic
When I push the 4X4 button I can here the relay click but the transfer case does not engage. I assume it is the solenoid/motor on the transfercase is bad. Is this assumtion correct and if so how hard is it to change?
Old Nov 19, 2001 | 11:59 AM
PAUL_2's Avatar
PAUL_2
More than likely the motor that engages the transfer case is the problem , I think if you do a search on this topic you will find where some people have rebulit those motors .
Old Nov 19, 2001 | 12:14 PM
bdonalds's Avatar
bdonalds
I had this very problem last winter. My problem was "gunk" in the shift motor. Here is a link to my saga....
https://www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=read_count&om=268&forum=DCForumID39
Hope this helps!
Bryan
Old Nov 20, 2001 | 07:37 AM
Hartwood's Avatar
Hartwood
Old Nov 20, 2001 | 08:38 AM
tobins's Avatar
tobins
[updated:LAST EDITED ON 20-Nov-01 AT 09:44 AM (EST)] Thanks for the help guys, I will take a look at the motor and thanks for the link. One mor thing what seals should I pickup before removing the motor and opening it up?
Old Nov 20, 2001 | 09:09 AM
thoseapples's Avatar
thoseapples
You may find this link of interest:
[a href]http://www.glue.umd.edu/~singletn/exp.html[/a]
It's an Explorer page, but the basic similarities are there. That link directs you to the navigation page, and from there you'll find an article on transfer case repair. A very, very informed site with hands-on experience behind most of the articles.
Old Nov 20, 2001 | 09:26 AM
tobins's Avatar
tobins
This is really good info on my problem thanks for the help, I will let you all know how it goes.
Old Nov 20, 2001 | 02:48 PM
bdonalds's Avatar
bdonalds
I was able to fix mine without removing it from the transfer case. As far as a gasket, I just used some "gasket in a tube"...I am not sure if there is an actual gasket for the little cover I pulled off.
Good luck!
Bryan
Old Nov 21, 2001 | 11:42 AM
tobins's Avatar
tobins
That fixed everything, I didn't have to drain the transfercase, but I did cut the wires so I could clean it up some. I also replace those torx head bolt with 3 8/32 by 1/2" slot head bolts. All that was needed was to clean the brushes, contact surfaces, and the ceramic disk. Works like a charm, thanks for all the help!
1993Ike
1978 - 1996 Big Bronco
Feb 21, 2010 12:51 AM
mengonij
Nov 16, 2009 10:26 AM
oosdun
1983 - 2012 Ranger & B-Series
Dec 7, 2006 05:50 PM
Zukster
Oct 18, 2004 02:36 PM
Captbo2001
Offroad & 4x4
Oct 3, 2004 10:58 PM
