Keyed 12V Source????
Old Jul 10, 2017 | 10:43 PM
sdm300's Avatar
sdm300
Originally Posted by rebauto
This SEIC doc also describes the circuit descriptions and color codes of the wires in the passenger fuse box area. CBP22, tapped by rebauto, is 12V, 5A fused run/start circuit.
The doc also points out 4 pass thru wires, handy for those of us without upfitter switches....
Old Jul 11, 2017 | 11:56 AM
rebauto's Avatar
rebauto
Good info SDM300, Thank You! Wish I would have had that when I was doing the Initial upfitting...
Old Aug 25, 2021 | 06:05 PM
jimi.martin87's Avatar
jimi.martin87
5th Gear
Doc link is dead, where can i find it elsewhere?
Old Aug 25, 2021 | 07:55 PM
sdm300's Avatar
sdm300
PM me your email, I will send you a copy
Old Aug 25, 2021 | 10:32 PM
jimi.martin87
5th Gear
I think I did just now. But I'm not sure. I suppose I'll know if I get your email.
Old Aug 27, 2021 | 04:19 AM
B-ManFX4's Avatar
B-ManFX4
Old Feb 9, 2022 | 01:51 PM
TomHay's Avatar
TomHay
4wd Low
this is an old thread...but thought i was relevant....i have a plow wired into the green/orange as is shown above. All of a sudden the plow (controler) is not getting power...any ideas of why that would happen? And, are there fuses i should check that correspond to this wiring bundle?
Old May 10, 2022 | 05:55 PM
bart0's Avatar
bart0
Yeah there is a fuse box right next to the PTO/SEIC bundle (at least on my 22). The fuse is in there.
Old May 13, 2022 | 07:51 AM
slapshot12's Avatar
slapshot12
Originally Posted by k7lvo
Where did you pick up a ground near the fuse panel?
I used an Add-a-Fuse to one of the fuses in the passenger kick panel fuses box for my dash cam on my previous 450. There is a bolt right next to it that I used for the ground. I don't know if there's a fuse in the that will handle the load of a compressor though. They can draw 20-30a.
Boatdude60
Sep 12, 2018 09:30 AM
Desert Don
6.7L Power Stroke Diesel
113
Aug 22, 2018 01:52 PM
Chevmn56
Jun 21, 2017 09:55 AM
wfoskir
Feb 14, 2009 11:55 AM
mnge03
Oct 3, 2005 08:09 PM
