Sponsored by: Real Truck
upfitter switches
Old Sep 30, 2005 | 05:35 PM
mnge03's Avatar
mnge03
Lightbulb upfitter switches
Hello everyone,
I have reacently purchased a new 2006 F250SD. It is equiped with upfitter switches in the dash. Great, now I can hood up my off road lights! Just one problem, the wire leads that the owners manual states should have the 30amp or 10amp output when you activate the switches are dead. No power. Does any one out there know the location of the output leads from the upfitter switches? Thanks for the help.
MNGE03
Old Sep 30, 2005 | 06:05 PM
rwilimo's Avatar
rwilimo
Your post is a little confusing but here goes. To access the correct wires, pull the dash panel under the steering column, remove the 4 bolts from the fuse box, pull to box out a little and you should find the 4 upfitter wires with black heat-shrink over the ends. Hope this helps.
Old Sep 30, 2005 | 08:20 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
I'd guess you're looking under the hood for the wires? That's not them - under the dash, behind the fuse panel.
Old Sep 30, 2005 | 10:27 PM
Ford_Doctor's Avatar
Ford_Doctor
I think you will find this document will answer all of your upfitter switch questions:
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
I recommend printing this!
Old Sep 30, 2005 | 11:07 PM
sriddle's Avatar
sriddle
I used the wires behind the fuse panels and they work. Somewhere I have the wire detail if needed.
Old Oct 2, 2005 | 10:42 PM
johnw's Avatar
johnw
I think I saw a link to a Ford bulletin that described how to convert the upfitter switches to work with the ignition switch turned off. Am I correct, if anybody has it, would they repost? Thanks, John
Old Oct 3, 2005 | 07:04 AM
rwilimo's Avatar
rwilimo
See my answer here: https://www.ford-trucks.com/forums/s...d.php?t=410872
Old Oct 3, 2005 | 08:09 PM
mnge03's Avatar
mnge03
Thanks everyone for the help, I found them right where you said to look. Behind the fuse pannel.
