Help Please!!!!!!!
Old Jun 20, 2017 | 03:09 PM
Chevmn56's Avatar
Chevmn56
Help Please!!!!!!!
Does anyone know of a 12v Keyed source under the hood drivers side???
Thanks in advance
Old Jun 20, 2017 | 04:55 PM
mhoefer's Avatar
mhoefer
Upfitter switch wires under passenger dash, pass through wires from upfitter to under hood pass side, connect to those. Depending on the amperage you need, switches have some differences, 5 and 6 are 40 amp, they are all relayed and fused.
If you don't have upfitters, then well, you have more wiring to do....
Old Jun 20, 2017 | 05:36 PM
maabx's Avatar
maabx
The under hood power distribution box on the passenger side should have many circuits that are active when the ignition is on. You can piggyback off of an existing circuit with one of these...
Amazon Amazon
Old Jun 20, 2017 | 10:37 PM
mhoefer's Avatar
mhoefer
You can use a fuse tap, to access a circuit, but be careful not to tap something sensitive electronically like engine or trans or controls or something important like headlights. Ideally 12 v feed to t he charger plugs in the cab, least potential issues.
Old Jun 20, 2017 | 10:41 PM
k7lvo's Avatar
k7lvo
Except that they're not really a "keyed source." Yes, they turn on with the key, but they stay on for quite some time after the key is off.
Old Jun 21, 2017 | 09:55 AM
mhoefer's Avatar
mhoefer
It won't make much of a difference, it's minutes that some circuits remain on, vs hours, in order to protect the batteries. Best way to do this is to use upfitter switches for the appropriate size circuit. Personally not a fan of fuse taps, but for something small, with a low load, an accessory circuit would work. OP doesn't mention their plans so it's hard to give advice.
JDJR59
Feb 14, 2024 01:09 PM
Boatdude60
Sep 12, 2018 09:30 AM
rustyshakelford
Nov 29, 2016 03:28 AM
Liquid10Rider
Nov 20, 2011 12:43 PM
wfoskir
Feb 14, 2009 11:55 AM
