Does everything seem normal?
Old Jun 12, 2017 | 08:09 PM
Apocalypse's Avatar
Apocalypse
Disregard what I say about the turbo flutter, I had no idea the 6.0 didn't have a wastegate
Old Jun 12, 2017 | 08:30 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I watched a couple of times and didn't catch anything real odd going on except max boost looked like 21psi. 27 or 28 would be better. I'm not sure but that could have been because the coolant was still in the 120° range. I usuially don't romp on one hard until it's fully warmed up. 185ish. EBP spiked up there pretty good but I don't think that's unusual. I really only watch that KOEO and idle. I thought I saw 160 and it's labeled PSI so that seems like a lot.
Old Jun 12, 2017 | 10:37 PM
silverbullet6oh's Avatar
silverbullet6oh
I agree with the boost being low, but like Rusty said, that truck is still cold!
I think you voltage seems a little low. Looks like it was mostly between 13.1-13.3, with a once in a while 13.4 and 13.5.
When I had mine with a DC Power 185 it would stay between 13.5 low to 14.1 high.
Old Jun 13, 2017 | 12:54 AM
Apocalypse's Avatar
Apocalypse
I'll go out again tomorrow and let it warm up first. It does have an egr delete and is supposedly bullet proofed. The seller also said he did something with the turbo. Something like replacing the back half with a power max or precision something. It's nice and shiny on one half either way.
Old Jun 13, 2017 | 09:40 AM
DarkStarMedia's Avatar
DarkStarMedia
I will certainly be interested in your outcome. My truck has the same 21-22 psi boost limit doing an unloaded pull up to highway speed.
Richard
Old Jun 13, 2017 | 11:50 AM
navistarnut's Avatar
navistarnut
Richard
I have a hard time hitting 24 unloaded, towing she climbs up to 27/28 no problem.
I have read other threads that a deleted truck will see slightly lower boost
Old Jun 13, 2017 | 05:43 PM
bismic's Avatar
bismic
Same here .
Old Jun 17, 2017 | 12:52 PM
Blakshukvw's Avatar
Blakshukvw
My 03 X is egr deleted with no valve plugged in. I've been told that like this if any codes are ever erased it loses the vgt strategies and then will not exercise the vgt when it should. This could lead to a sticky unison ring causing low boost.
The fix is install or at least plug in an egr valve and then get I the strategies relearned. Mine typically makes 22 to 23 rarely 25lbs. I also have a stock turbo in good condition.
Old Jun 18, 2017 | 02:02 PM
brandonrr's Avatar
brandonrr
Without the EGR valve plugged in, your cooling fan operation gets affected, not the turbo strategy.
Old Jun 18, 2017 | 02:30 PM
Blakshukvw's Avatar
Blakshukvw
I personally believe you are incorrect on both matters. Anthony at super duty service says he's never seen a fan issue from no egr valve. Ihaven't seen any fan performance decrease without the egr. As well I also watched my truck on the IDS not be able to acquire the vgt strategie because it couldn't pass the egr test. He said that is very common and always recommends the actual egr valve be installed.
Old Jun 18, 2017 | 03:38 PM
Tideman's Avatar
Tideman
I think the 03 - 04 have no issues with the EGR Valve unplugged. The 05 - 07 do. The fan will not operate properly.
Old Jun 18, 2017 | 04:41 PM
Blakshukvw's Avatar
Blakshukvw
Except for the egr strategie. As soon as Anthony plugged in an egr on my truck it went through its paces and then acquired the vgt strategie.
allingeneral
Oct 7, 2015 09:03 PM
BryanStein
Sep 17, 2013 08:49 PM
megawatt00
64
Aug 25, 2009 06:16 AM
akula22
Jun 17, 2007 09:57 PM
Firemedic61
May 26, 2006 07:05 AM
