Knock knock knock...
Old Jun 12, 2017 | 11:50 AM
Fords & Whalers's Avatar
Fords & Whalers
Hi folks. I have a 1965 f100 with a rebuilt 352, 3-speed C-6 transmission and 9-inch rear end. Recently I noticed a ticking sound when I was turning hard left from a dead stop, but didn't think much of it. Now there is a steady knocking coming from the rear end. The steady knocking is present when I coast in neutral with the engine off. It appears to synchronize with the drive train and not the wheel rotation... about two knocks for every wheel rotation. It sounds like tapping on a body panel. I had the rear brakes inspected and everything is solid. The knocking Igoes away when I brake moderately and when I accelerate. There is also a noticeable vibration on deacceleeeration above 20 MPH. I'm likely going to bring her to a local transmission shop next week for inspection but was wondering if anyone here had an quick fix, opinion or.armchair diagnosis? Thanks in advance! --Rob--
Old Jun 12, 2017 | 02:14 PM
wyrm73's Avatar
wyrm73
Check your U-joints and driveshaft support bearings.
Old Jun 14, 2017 | 01:03 PM
Fords & Whalers
Checked u-joints and seem tight and I don't have any drive shaft supports. I'm taking it up to a drivetrain Specialist in Santa Rosa Friday Morning, hopefully it's something simple.
Old Jun 14, 2017 | 01:17 PM
Fords & Whalers
I'm assuming this is a stock 9" rear end?
Old Jun 14, 2017 | 02:54 PM
wyrm73's Avatar
wyrm73
It's kind of hard to see in the picture, but that looks like it has a bolt on cover on the back of the differential- that would make it a Dana, not a 9". On a F100, it should be a Dana 44 if I am not mistaken. I know the Dana 60 was used in later years, but I'm not 100% sure with the slicks.
Old Jun 16, 2017 | 10:01 AM
skidoorulz's Avatar
skidoorulz
Dana 60-2?
Old Jun 16, 2017 | 11:54 AM
Fords & Whalers
Stamped 1L8 22
Old Jun 16, 2017 | 11:58 AM
Fords & Whalers
here's a pic
Old Jun 16, 2017 | 03:33 PM
Fords & Whalers
Not brakes, not the differential, not the transmission, not the u-joints. Ugh...
Old Jun 22, 2017 | 02:02 AM
F-ONE's Avatar
F-ONE
Check the motor and transmission mounts.
Old Jun 22, 2017 | 11:06 AM
Fords & Whalers
Will do, didn't think of that! The u-joints look fine upon visual inspection, and I'm considering swapping in new ones just to complete the process of elimination. The rapping sound has decreased but is not gone. The noise is coming from the drivetrain but for the life of me I can't pinpoint it. I've has several mechanics scratching their heads too. Walking along side the rig coasting in neutral with the engine off, there is a thump thump that coincides with the rotation of the drive shaft. There is a slight but visible shutter at the rear of the truck that also coincides with the thumping. The vibration at deceleration has also decreased, but is still noticeable.
Old Jun 29, 2017 | 01:56 PM
Fords & Whalers
Problem solved...rear outer wheel bearing. Replacing both for good measure.
Old Jun 29, 2017 | 09:59 PM
wyrm73's Avatar
wyrm73
Good plan. The other bearing can't be far behind in wear and Murphy says it will fail when you are farthest from home or on the hottest/ coldest day of the year. Probably raining too.
Usually wheel bearings are more of a constant humming rather than a thunk sound, so that one is a bit of a surprise to me. Glad you were able to sort it out.
79Courier
1983 - 2012 Ranger & B-Series
Feb 27, 2015 07:26 PM
brndnw1023
Feb 2, 2013 03:54 PM
RussB
Feb 12, 2011 06:14 PM
aaronlockhart
Sep 17, 2007 04:53 AM
jbone108
2004 - 2008 F150
Nov 7, 2004 06:46 PM
