Clutch master and slave cylinder help!!
89 f250 7.3 idi Zf5 transmission my shifter lever broke clean off at the base under my shift boot my clutch was working just fine then all of a sudden it just went dead went straight to the floor and didn't come back up had to pick it up with my foot this has happened before but clutch returned back to normal After a few seconds of pumping the clutch I'm guessing either my master or slave cylinder went out I couldn't put it in gear at all I tried again to put it in first and then snap shifter lever just broke good thing it's sitting in my apartment parking lot what do y'all think it is
Go underneath and look!
Check to make sure something didn't happen to the lever going from the slave cylinder into the bellhousing.
Also, you broke the shifter lever because you tried to put it in gear with the clutch effectively out, so it wasn't going to engage.
You can weld it up or replace that piece.
Idk cause I'll have no clutch and then it will come back the rest of the day if I open the master cylinder and pump the clutch a few times then it's normal again maybe their is air in the line cause I've had to add fluid a few times maybe slave is leaking drive shaft is has fluid on it
so my shifter upper half is not broken its the lower half of the shifter were the to holes to bolt the upper half of the shift lever is broken you think I can weld that back together or at least use jb weld till I find a part to replace it
This piece were the two holes right under it is were it broke sorry not my pic it's for reference
Get that slave cylinder fixed too (;
mattri
01-15-2016 05:40 AM
phil33
01-11-2003 06:29 PM
