Ignition problem
Old Jun 10, 2017 | 04:28 PM
slour's Avatar
slour
Cool Ignition problem
I'm having intermittent issues with ignition on my 77 F250 with a 351M, I have replaced the ignition coil, the rotor and the distributor cap. I haven't replaced the ignition coil resistor or the ignition module. Before I go any further I thought I would seek some advice. Like I said at the beginning the problem is intermittent, doesn't seem to matter if the engine is warm or cold, what ends up happening is that the starter will turn over and over with out the engine picking up then as I let off the key and allow it to go from the start position to the run position the engine will pick up. Again this is not always the issue but it seems to be true more often than not. Any advice would greatly be appreciated.
Old Jun 10, 2017 | 05:21 PM
slour's Avatar
slour
and because I know vacuum issues can cause trouble too, I also have this problem going on. the PO rebuilt the carburetor and didn't hook everything back up correctly, if anyone knows where the two hoses pictured with the wood screws in them go I would greatly appreciate it.
Old Jun 10, 2017 | 09:04 PM
PapaBearYuma's Avatar
PapaBearYuma
Classic symptoms of a bad pickup coil inside the distributor.
Austin Hartman
Aug 2, 2016 08:37 AM
Sportsterengr
17
Apr 7, 2016 09:08 PM
backdraft341
Jun 30, 2010 09:46 AM
irishguyincc
1983 - 2012 Ranger & B-Series
38
May 2, 2006 08:02 PM
swooshcmk
May 25, 2002 09:18 PM
