2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Anyone have any tips for removing the stock caster bushings?
Old 06-26-2017, 03:04 PM
FmaxTurboSi's Avatar
FmaxTurboSi
FmaxTurboSi is offline
Did you ever get the caster bushings switched out??? How'd you end up getting it budge finally?
Old 07-24-2018, 06:46 AM
lasallen's Avatar
lasallen
lasallen is offline
Originally Posted by wb6anp
NOTICE: The caster/camber adjustment sleeve must be removed and the axle bores and adjustment sleeve contact areas cleaned to ensure proper torque sequence. If not clean, damage to the ball joint, adjustment sleeve and/or axle bores can occur.
NOTICE: Failure to remove the caster/camber adjustment sleeve can result in a hard to steer condition.
Thoroughly clean and inspect the axle bore and adjustment sleeve contact areas.
Install the camber adjustment sleeve.
NOTE: Only tighten the nut finger tight at this stage.
Position the knuckle onto the axle and install the upper ball joint nut.
Install the new lower ball joint nut.
Torque : 44 lb.ft (59 Nm)
Install the upper ball joint nut.
Torque : 69 lb.ft (94 Nm)
NOTE: If necessary, tighten the nut until the cotter pin can be installed.
Install the new upper ball joint cotter pin.
Torque : 150 lb.ft (204 Nm)
I guess they mean just finish torquing the lower nut.
Not this easy on 4wd, anyone have any other ideas?
bullnose1985
21
05-21-2017 08:20 PM
crandallf150
08-06-2016 11:32 AM
Steve in NC
04-01-2015 11:36 AM
acf6
1999 to 2016 Super Duty
06-07-2012 09:42 AM
Violjohn78
03-30-2004 10:34 PM
Quick Reply: Anyone have any tips for removing the stock caster bushings?
