2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Anyone have any tips for removing the stock caster bushings?
Old 06-04-2017, 01:34 PM
Tricon's Avatar
Tricon
Tricon is offline
I've tried whacking on em, air chisel, pry bar, I'm guessing there's some tip I'm missing.
Do I need to remove the ball joint to get it loose?
Any help is appreciated!
Old 06-04-2017, 01:47 PM
Tricon's Avatar
Tricon
Tricon is offline
I'm dead in the water at this point right now:
Old 06-04-2017, 01:51 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
I am looking in the service manual.
NOTICE: To prevent damage to the ball joint seal and the ball joint socket, do not use a pickle fork-type remover to loosen the ball joints.
Strike the lower and upper end of the axle to loosen the ball joints and the camber adjustment sleeve.
Remove the camber adjustment sleeve.
Use the General Equipment: Two Leg Puller
Remove and discard the lower ball joint nut and remove the front wheel knuckle.
Old 06-04-2017, 01:55 PM
Tricon's Avatar
Tricon
Tricon is offline
Awesome, thanks 👍
Old 06-04-2017, 02:09 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
NOTICE: The caster/camber adjustment sleeve must be removed and the axle bores and adjustment sleeve contact areas cleaned to ensure proper torque sequence. If not clean, damage to the ball joint, adjustment sleeve and/or axle bores can occur.
NOTICE: Failure to remove the caster/camber adjustment sleeve can result in a hard to steer condition.
Thoroughly clean and inspect the axle bore and adjustment sleeve contact areas.
Install the camber adjustment sleeve.
NOTE: Only tighten the nut finger tight at this stage.
Position the knuckle onto the axle and install the upper ball joint nut.
Install the new lower ball joint nut.
Torque : 44 lb.ft (59 Nm)
Install the upper ball joint nut.
Torque : 69 lb.ft (94 Nm)
NOTE: If necessary, tighten the nut until the cotter pin can be installed.
Install the new upper ball joint cotter pin.
Torque : 150 lb.ft (204 Nm)
I guess they mean just finish torquing the lower nut.
Old 06-04-2017, 02:20 PM
Adam R's Avatar
Adam R
Adam R is offline
The 2-3lb brass hammer from Harbor Freight is great addition to any tool box. Although probably not impossible, I have yet to do any significant damage to threads when I beat on the exposed stud with a big brass hammer. It transmits a lot of force and shock without damage to the threads.
Adam
Old 06-04-2017, 02:28 PM
Tricon's Avatar
Tricon
Tricon is offline
I might just pay someone to do it, I can't seem to get to the lower nut to loosen it. I wish it wasn't 90 degrees out right now...
Old 06-04-2017, 02:38 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
it does say to remove the tie rods as well
Old 06-04-2017, 06:44 PM
skanj0's Avatar
skanj0
skanj0 is offline
A propane torch and some penetrating oil. Heat the knuckle around the outside of the caster cam and then apply penetrating oil. Then a good whack on the front edge of the knuckle with a 3lb sledge. Made it easy on my 06 and my 2016.
Old 06-04-2017, 08:02 PM
mooch91's Avatar
mooch91
mooch91 is offline
On a new truck, it shouldn't be too difficult to get them out.
When I did my leveling kit on my 07, I simply soaked them with penetrating oil then whacked really hard on the top of the stud with a brass drift (Harbor Freight) and a hammer. After a few strong whacks, they loosened up and popped right up.
Try to avoid hitting the stud directly with a hammer - you risk messing up the threads.
Old 06-05-2017, 07:25 AM
kylant's Avatar
kylant
kylant is offline
make sure all the weight is off the axle.
leave the nut on the ball joint stud, but loosen it.
just whack around the ball joint stud on the knuckle. is should break it loose. then gently pry the sleeve up.
don’t need to do anything with the lower
Old 06-11-2017, 03:04 PM
FmaxTurboSi's Avatar
FmaxTurboSi
FmaxTurboSi is offline
just curious.... is it necessary to change the caster bushing if you do a 3.5" level with the radius arm drop backets??? Or is it only necessary when you leave the radius arms in the factory position?
Thanks
Old 06-11-2017, 05:03 PM
Tricon's Avatar
Tricon
Tricon is offline
Thanks
No, the radius arm brackets are your caster adjustment.
Old 06-11-2017, 09:38 PM
FmaxTurboSi
That's what I figured.......
Can't wait for you get your carli springs installed. I bet your truck is gonna be insane with the 2.5's and everything.
Old 06-11-2017, 09:43 PM
Tricon's Avatar
Tricon
Tricon is offline
Me either! I'm kind of dragging my feet waiting to see if my buddies come up with something from their attempts with eibach springs, but I'm not known to be a patient man lol.
Quick Reply: Anyone have any tips for removing the stock caster bushings?
