EBP Valve Partially Closing
Old May 31, 2017 | 05:02 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
After running highway speed then stopping, the EBP valve is partially closing as you accelerate back up to speed. You can hear it in the sound of the motor, and you can see it on EGT's, which are rising quickly. This happens briefly then corrects. We unplugged the EBP sensor and the problem continued. Tube is clear.
If I monitor the EBP sensor, what values should I see if it is functioning properly?
Thanks in advance!
Old Jun 1, 2017 | 12:32 AM
Karlow's Avatar
Karlow
The EBV is operated based on engine temperature. Maybe it thinks it's cold.
Old Jun 1, 2017 | 06:57 AM
ExPACamper's Avatar
ExPACamper
Did you check to see if your EBPV actuator is leaking at the pedestal?
It may not have the holding power to keep it open under load?
Old Jun 1, 2017 | 07:25 AM
Tugly's Avatar
Tugly
The EBP regulator needs a signal to activate the EBPV, it doesn't need anything to hold it open. It sounds like maybe the turbo pedestal needs a rebuild - or the EBPV linkage has an issue.
Old Jun 1, 2017 | 08:32 AM
AllaboutMPG's Avatar
AllaboutMPG
So if you unplug the EBPV at the base of the pedestal would that eliminate the signal? Narrow down whether or not it's mechanical or electrical?
Old Jun 1, 2017 | 04:32 PM
Whitey Ford
So we are going to try to reenact issue and graph EBP, EOT, MAP. Anything else?
Old Jun 1, 2017 | 06:07 PM
Whitey Ford
With the EBPV's signal eliminated by disconnecting the plug at the pedestal, what directs the EBPV to move?
Old Jun 1, 2017 | 06:58 PM
AllaboutMPG
I would say it shouldn't move without a signal to command it.
My thought was to narrow your problem down to either electrical, getting a signal when you shouldn't
or mechanical the actuator is bad letting the EBV close when it shouldn't.
Old Jun 1, 2017 | 09:07 PM
ExPACamper's Avatar
ExPACamper
The EBPV actuator/piston assembly is supposed to be pre-loaded to keep the EBP flapper closed, unless actuated by oil pressure, triggered by the EBPV solenoid.
The arm is attached to a piston and spring in the horizontal cylinder in the base of the pedestal. Oil introduced through ports into this cylinder pushes the piston and rod to open the butterfly valve.
Here are the instructions, detailing the preload and some details.
I just rebuilt mine. If you need some pics, I can take some of the old parts tomorrow after my am appt.
File Type: pdf
Old Jun 2, 2017 | 09:14 AM
Walleye Hunter's Avatar
Walleye Hunter
Can that be rebuilt without removing the pedestal?
Old Jun 2, 2017 | 09:30 AM
AllaboutMPG
Probably but it would be like changing your underwear in a straight jacket.... not easy, and take forever
Old Jun 2, 2017 | 11:20 AM
ExPACamper's Avatar
ExPACamper
Rebuilding Ebpv
Depends... Have you ever honed a cylinder through a glowplug hole?
Master that first, then wirh special tooling it would only be "near" impossible, lol.
But seriously, I've done crazy things like that, working deep inside cavities packed tight with wiring and other components, but I think you'd be very likely to fail cleaning and inspection part
hakukamana
Feb 26, 2013 10:43 PM
94WhiteF250
Dec 31, 2010 12:19 PM
97F350PowerStroke
Jan 29, 2007 09:55 PM
yamahahauler
Jan 10, 2007 05:30 PM
cdiddy
Dec 12, 2006 07:41 AM
