Rebuilt 400 issues after break-in
Hello all, having some problems after my rebuild. It's a '77 f150 4x4 w/ 400 C6. Has CA emissions. Edelbrock timing chain set straight up. Edelbrock performer cam and lifters stock valve train. Edelbrock performer EGR intake and stock 2bbl carb. Upon first start up had a small tap but after the break-in period that disappeared. Idled fine after and I was able to fine tune the timing. All seemed well so I shut her down. I then reattached the A/C bracket and took a break for
about 2 hours. When I went to restart the truck it sounded like it had slipped out of time. Maybe missing on one or two cylinders and wouldn't idle. Not sure where to look first. Any suggestions are appreciated.
on
Might you have jostled your distributor wiring when installing the AC bracket? If you're running the original distributor, Duraspark box, and harness, it's possible that the insulation has dry rotted and is crumbling and falling off, leading to short circuits.
Chased this problem for a few months on an '84 Capri RS 5.0, and finally narrowed it down when it happened immediately after an oil and filter change. Most of the time mine would stop running, but I think sometimes it would stay running, but like crap.
78f250_rls
04-08-2005 02:24 PM
