timing
Old Oct 3, 2004 | 12:08 PM
78_ford_F150's Avatar
78_ford_F150
timing
i have a rebuilt 400 with hedders performer plus cam and the true roller timing chain its timed at 12 btds that is what my dads stock 400 is timed at should i leave it or change it
Thanx Justin
Old Oct 3, 2004 | 07:14 PM
bhawkin2's Avatar
bhawkin2
I was always told 6 degrees TDC.But if I'm wrong I've been setting my timing wrong for years.
Old Oct 3, 2004 | 11:08 PM
78_ford_F150
before tdc or after
Old Oct 4, 2004 | 12:30 AM
Loan Ranger's Avatar
Loan Ranger
Any 400 Ford that I have experience with was timed at 6 degrees BTDC. This includes breaker point and electronic ignition.
Your truck with 12 degrees BTDC seems to me to be advanced pretty much, actually.
Old Oct 4, 2004 | 05:05 PM
bhawkin2's Avatar
bhawkin2
Im sorry guys it is 6* BTDC
Old Oct 4, 2004 | 06:03 PM
BrentKasson's Avatar
BrentKasson
Mine is set at 14* btdc i think stock is 12. CA timing was at 6* if I remember right
Old Oct 4, 2004 | 10:45 PM
78_ford_F150
i changed it to 6* btds at idels nicer and seems to pick up faster wen i step on it to so im going to leave it a 6*
and as i said at the top it is rebuilt but it is useing oil i was told that it is normal to burn oil during the breakin period the motor has 900 km on it
Old Oct 5, 2004 | 05:37 PM
bhawkin2's Avatar
bhawkin2
I looked it up in our mitchells at work today it says 6* btdc.
Old Oct 8, 2004 | 02:58 PM
unreng's Avatar
unreng
Arrow
78,
6* is usually for automatics and 12* is usually for manuals. If the truck is running well at 12*, I'd leave it alone. I'd wait until the engine is broken in and the curve the distributor to the engine (have a shop perform the work or DIY).
Old Oct 8, 2004 | 03:14 PM
bhawkin2's Avatar
bhawkin2
It is 12* on manuels.Do you have an auto or manual?
Old Oct 8, 2004 | 06:15 PM
78_ford_F150
i have a auto but my dads 79 is a auto and it said rite on the tapit cover 12*
Old Oct 9, 2004 | 06:45 PM
bhawkin2's Avatar
bhawkin2
Is your dads truck all original?
Old Oct 10, 2004 | 12:37 AM
Loan Ranger
If the engine is old enough, it will have a metal tag affixed to the front of the engine, usually at the thermotstat housing, that will give you the build date code and the model year and model code for which it was built. If the engine was built after 1973, it will have a decal on the passenger side valve cover at the very front of the cover which gives the information.
If the tag is missing or the decal is destroyed or illegible, there will be a cast date code on the driver's side of the block, right above the oil pan mounting flange.
This information--excluding the CAST date code--will tell you even what vehicle the engine was calibrated for originally. The cast date code, of course, just lets one know WHEN the block was cast. (The original tag or decal will tell you what engine plant built the motor; the block will have a cast letter(s) which tell you what foundry cast the engine--either Cleveland Foundry or Michigan Casting Center.)
I hope this will help you in trying to determine the originality of the engine for the truck.
Old Oct 10, 2004 | 02:18 PM
78_ford_F150
yes my dads truck is all original
Christian Wickett
Jul 15, 2017 09:42 AM
Red1111
Mar 16, 2017 06:37 PM
MattMac
Feb 23, 2017 08:00 AM
clhart426
Jul 29, 2011 03:41 PM
78Ranger400
Apr 21, 2011 04:22 PM
