Bronco Build questions
If you're set on going carbed, you can basically remove everything emission-related, the EGR inlet/outlet will need to get plugged, the smog pump can be gutted and used as a pulley or removed/bipassed and the belt replaced with a shorter one (depends on the belt routing, but I think yours uses several belts so it should be easier), for all I know you can remove the ECM since there will be nothing else to control, I would protect the plug from the weather anyway. I'm sure there are more steps to it, but that's all that comes to mind.
Which Offenhauser intake do you have? If it is a C style (one big open hole for the carb), then yes, you can use a Motorcraft 2100, which from everything I've heard is a simple and reliable carb. If you have the Offenhauser DP (four individual holes) then you must use a four barrel carburetor. In my experience, setting up the secondaries on a four barrel is the easy part, so a 2bb and 4bbl carb have the same level of difficulty to set up.
Yes, you need to change your ignition. The 86 used a computer controlled ignition and electronically controlled carburetor. ALL of it needs to be working properly to function, so if you do something like remove the carburetor, then it'll shut down and run in LIMP mode and your timing won't advance.
For the DuraSpark II, you will need an ignition module (you should already have holes on the driver's side wheel well for mounting it), a DSII distributor, coil, and then the wiring harness. The harness can be purchased new online, or you can dig one out of a junk yard. It's all just plug and play and will all go right in like it was made for it. I did a swap to a DuraSpark II ignition on my '84 (also computer controlled) and it took about 30 minutes. Most of the time was spent just yanking the old stuff out. You'll be amazed at just how much less is under the hood.
There is also a computer underneath the dash behind the steering wheel. It can go too. As well as that massive chunk of wires going through the firewall to the computer can go, and you can get a delete plug to close up the hole.
Now, I've heard off-and-on that the '86 isn't as plug-and-play as the '84 and '85, but I've never been able to confirm it. Just something to consider. I've never heard it stopping anyone, but it's something you may run into.
Another option is just to buy a single wire, HEI style ignition and run that. You won't have to worry about any wiring except a 12v key on source. It is the ENTIRE ignition, so you won't have to worry about anything else. Performance Distributors used to be the only one that made one, but now Summit has their own version as well.
https://www.summitracing.com/parts/d...view/make/ford
https://www.summitracing.com/parts/s...view/make/ford
As far as the emissions stuff, you can take it all out. You can't use any of it with the EFI manifolds anyway since it's all designed to tie in with the stock 1bbl manifold. The EGR, smog pump, etc. can all go. (I would, however, recommend a 2.5" catalytic converter, even if you don't require it. They do a lot of good and have very little, if any, detriment to performance).
Hope that helps!
Hope that helps!
On my build, I used the Walker 45166. It looks like it's getting a little more difficult to find, but Autozone still has it on their site.
Walker Exhaust Pipe 45166 - Read Reviews on Walker #45166
Summit lists it as: "Not available".
If you get it, just be sure to use an extension and a grinding burr and clean out the rear hole. They don't always cut it open all the way. It took about 30 minutes on mine but was well worth it.
Did you get the harness off of a truck with an I6 or a V8? I've heard the wiring harness is the same, but maybe not? There are some wiring diagrams floating around, so maybe one of those can tell you which wire goes to what. Try some searches and see what pulls up.
As for the coil, no, the starter doesn't have anything to do with the ignition. The starter spins the engine when you turn the key all the way, and the ignition simply detects when the engine is spinning (as long as it has power). They're independent of each other.
The best way to find your timing mark is to pull the #1 spark plug and then rotate the engine until the piston comes up to the highest position. Then, look at your timing marks and see. On some balancers, you'll have a timing mark for both the timing cover and the stamped mark on the passenger side. If so, use the timing cover. It's much easier to see and you can adjust the distributor and look at it at the same time. (Also, there's no timing chain, it's gear to gear).
https://www.google.com/search?q=dura...w=1920&bih=974
As for the tach, that's built in. If you already have a stock tach, you should be able to just plug it in and away it goes. I've never had to run a separate wire for it as it's built in. Normally, it goes to the negative post on the coil.
As for the two long wires. The shorter one goes to the oil pressure sender near the rear of the engine on the driver's side. The longer one goes around the back of the engine to the temperature sender underneath the #6 runner on the intake. The temp sender on the thermostat housing won't be used. It's for the computer only (you can remove and plug it).
Hope that helps.
My alternator has a few studs that aren't used. Just hook up the ones you need.
On mine, I hooked my electric choke up to the 7v peg. I used a volt meter while the engine was running to figure out which one it was. Most aftermarket carb installation instructions will tell you to use a 12v source, but I find this opens up the choke much too quickly, especially in cold weather. I found that using the 7v slows it down a bit and really helps.
If you want to double check the distributor, put something light, like a cotton ball, in the hole and rotate the engine clockwise until you can see it puff out. Unless you have a valve that's not closing, it should be a pretty healthy puff of air.
How did you set your timing?
As for valve lash, are your rockers adjustable?
