heeelp
Old Oct 12, 2005 | 12:06 PM
bobbyngeorgia's Avatar
bobbyngeorgia
heeelp
i have a 92 150 2 wd with a 4.9 300...i want to rebuild the motor but WITHOUT all the smog crap...can this be done?..please advise me I am new here,,,thanks Bobby
Old Oct 12, 2005 | 12:17 PM
Motorhead351's Avatar
Motorhead351
Yes it can.
Old Oct 12, 2005 | 12:39 PM
bobbyngeorgia
can you tell me where to get the info to do this? or would I be better off to go carb on it and get rid of all the computer crapp?
Old Oct 12, 2005 | 01:05 PM
Motorhead351
Honestly, there is little to gain by deleting a functional emissions systems.
If you have smog testing, which I am guessing you don't, then this isn't an option.
If a person were wanting to do this, they'd need to get a shorter serpentine belt to delete the smog pump. Block off plate for the egr valve. If you have air injecton in the head, you'd wanna put some sealer and bolts to replace those. Remove all the odds and ends and expect a check engine light, unless you leave the sensors attached to the harness or trick it with certain electronic components.
Whether you switch to carb is up to you, if your goal is a fair amount of hp and you don't wanna deal with chip companies/dyno time or wideband O2's, maybe its for you. To be honest though, you won't be saving much in the way of money, it costs almost as much to convert and efi engine to carb, as it does to set up the efi to work with the modifications made.
Good luck
