1978 - 1996 Big Bronco
Bronco top interchangeability
Old May 19, 2017 | 08:47 PM
Nick Wright's Avatar
Nick Wright
Will a top from an 80's Bronco fit on a 94? I realize it won't have the shoulder belts or third brake light, but other than that, will it bolt on?
Old May 20, 2017 | 12:36 AM
ZombieSlayer's Avatar
ZombieSlayer
It should line up easy peasy
Old May 20, 2017 | 11:41 AM
AlM's Avatar
AlM
Nick,
Swap, between 66-77, 78-79, 80-91, 92-96; "...78-79 fiberglass with integral steel roll bar inside rear lip; sliding or fixed side windows; 80-91 fiberglass with integral steel roll bar inside rear lip; sliding (up to 83) or fixed side windows; 92-96 fiberglass with integral steel roll bar inside rear lip attached to mounting plate & alignment pin; fixed side windows; The only groups that you can interchange are 80-96 with some modifications. 80-83 sliding side windows directly fit 80-96 shells. 78-91 Broncos use 4 short bolts (8mm head, 6x1.00x40mm) on each bedrail & 5 long bolts (8mm head, 6x1.00x70mm) in the upper sections. All bolts thread into U-nuts, except the 2 upper corners & the 2 rear corners which use captive nut plates. The bedrail bolts each use a clip stamped "L" or "R", but the rearmost bolts use the opposite clip. The clips for the B-pillar bolts are not marked, but the smaller tab goes down. 92-96 Broncos use 5 short bolts (tamper T-40 head, 8x1.25x30mm) on each bedrail & 5 long bolts (tamper T-40 head, 8x1.25x60mm) in the upper sections. All bolts thread into U-nuts, except the 2 upper corners & the 4 rear corners which use captive nut plates. The bedrail bolts each use a clip stamped "L" or "R", except the rearmost bolts. The clips for the B-pillar bolts are not marked, but the smaller tab goes down. There are also nut plates in 4 of the camper shell bolt holes: the 2 rearmost, and the 2 outboard at the top of the cab. They're just a heavy plate (1/4"?) with a threaded hole...."; AlM
NOTE; 92-96 have rear seat shoulder belt mounting points & 3rd brake lights.
Swap, between 78-79 & 80-96; "...NO, the 78-79 has a curved seam line going across the top and the 80-96 seam line is straight..." by Trent R
Swap, between 78-79, 80-91, 92-96; "...There are very few differences between the 80-91 and 92-96 tops. Some alignment pins is what it boils down to I think..."by Dobs
Old May 20, 2017 | 02:25 PM
Nick Wright
Wow that's a lot of info. Thanks! I found a top on CL with a missing window. I just want it for the shell, to bolt in without windows for cruising to the beach. I know the seat belts won't work and no third brake light.
The guy selling it doesn't know exactly what year it is, just "80's".
Old May 23, 2017 | 05:26 PM
AbandonedBronco's Avatar
AbandonedBronco
Basically the 80 - 91 tops are all the same and 92 - 96 tops are all the same.
The 80 - 91 tops have a pin in the body that lines up with a slot/hole in the shell.
The 92 - 96 tops have a pin in the shell that lines up with a hole in the body.
This just keeps you from swapping an older shell onto a newer Bronco because it is federally illegal to remove a shoulder strap belt and third brake light from a vehicle equipped with them.
But, If you put a 92+ shell on an 91 and prior Bronco, neither will have the alignment pin and you shouldn't have any issues.
Old May 23, 2017 | 08:07 PM
greystreak92's Avatar
greystreak92
Pins aside... (because they can be cut off). The only difference with the 92-96 (4th Gen.) tops is the addition of the shoulder harness rear seat belt mounts and the high-mount stop light. They will fit all the way back to 1980. Fortunately for 80-91 (3rd Gen.) owners, this makes it possible to add should harness rear belts and the stop lamp if you find yourself a 4th Gen. top to put on the truck and are willing to add some wiring.
Strictly speaking, if you are dealing with the removal of a 4th Gen. top with the original hardware still installed, you need the Tamper=proof T-40 Torx driver to remove it. Any top prior to 1992 should still have hex-head hardware holding it down.
Old May 25, 2017 | 01:47 AM
Nick Wright
Thanks guys!
Old May 28, 2017 | 11:09 AM
Encho's Avatar
Encho
The Southernmost Mod
The guys stayed on TOP of it
Indybeer
19
Sep 23, 2016 11:15 AM
AK Fifty-Three
Jun 11, 2007 01:26 AM
YankeeFan
Nov 30, 2004 04:19 AM
buckeyebronco
Aug 30, 2003 01:44 AM
UPBronc
Feb 28, 2003 12:39 AM
