1978 - 1996 Big Bronco
1993 Bronco door latch
Old 04-21-2017, 07:36 AM
1sscav's Avatar
1sscav
1sscav is offline
Back again with another Bronco question. My daughters Bronco's drivers door will latch, but not securely. When closed, the door will move about 1/4 inch back and forth when the handle is pulled. The door striker was worn and we replaced it, but it still wiggles. The striker has been adjusted, but was no help.
So, I'm thinking it's the door latch itself. The latch is tight in the door, but maybe the internals are worn? Does anyone know of a source for these latches? Are door latches interchangeable between driver/ passenger sides or model years?
Thanks again for any help.
Old 04-21-2017, 05:10 PM
Torky2's Avatar
Torky2
Torky2 is offline
Just to be real clear... so the striker bolt that is in there now has a good plastic bushing on it? Am asking as a check, because a missing/broken plastic striker bushing will allow exactly the condition you describe.
Old 04-21-2017, 10:53 PM
1sscav's Avatar
1sscav
1sscav is offline
Both door have brand new strikers and bushings.
Old 04-22-2017, 08:04 AM
para's Avatar
para
para is offline
Can your local stealer help you look that up and research it?
I'd bet anything that same latch is used on the F150.....they made 10X more of them
Old 05-25-2017, 08:53 PM
street rodder's Avatar
street rodder
street rodder is offline
Cant you get those from LMC? Bronco catalog.
Old 05-28-2017, 11:19 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Please recheck those strikers, and verify that the diameter matches the original parts.
cesspool
05-12-2010 11:27 AM
mantta
03-22-2007 10:14 PM
73highboy4x4
05-22-2004 10:15 AM
sethro
12-13-2002 03:24 PM
Quick Reply: 1993 Bronco door latch
