Rear Fender bolts
Your question is a bit too vague to answer...what style bolts do you have? The OEM setup had three small spot welds per bolt to hold them to the bedside. Aftermarket bolts on some beds have a square shank under the head of the bolt that fits into a square hole in the bedside (ala Mar-K). Some other aftermarket bolts have a beveled washer and a flat headed hex stainless steel bolt (Midfifty #81544) that looks very custom.
I guess that the simplest answer to " What is the best way to keep the rear fender bolts in place?" is to say that the bolts are held in place by the nut on the other end. I sense that this may not be the answer you seek but it is the way that most trucks have it. If you feel like you should have the bolts fixed to the bedside without a nut, then I would use a dab of structural adhesive under the head of each bolt. I am painting a bed right now and I went to a lot of work to break away the OEM spot-welded bolts so that I could more easily prep the bedsides and cut/buff after painting. Do your painter a favor and leave the bolts off until after the bed has been painted...those bolt heads are a PITA to sand around and even harder to buff.
My original bolts were welded to the bedsides. It sounds like yours were not? Dennis Carpenter has a full set of unpolished SS bolts, nuts, etc. for $30. They look like they have square heads: Rear Fender Bolt - Set | Dennis Carpenter Ford Restoration Parts
If you have a new bedsides you would have to cut square holes. This tool looks pretty slick for that: https://jet.com/product/detail/e5a67...EL8Q&gclsrc=ds
Maybe someone else has a better solution?
All the holes in my stock bed are round, I cut the original bolts off and popped them out with a center punch. it's beginning to puzzle me now after reading about all the square holes? I've discovered that the regular after market rear fender bolts with the square shank will fit really nicely with a little pressure. I wont install them until later at final painting.
The cost is in the labor involved with turning those beveled billet washers. It takes a screw mill and a jig to make it work. There was a guy here in SoCal that made these but unfortunately he passed some years ago...I believe that he was charging $2.25 each for the beveled washers and that was 15 years ago.
