Rancho Shocks #$%^&
Old May 18, 2017 | 11:52 AM
TrikeDawg's Avatar
TrikeDawg
I'm not buying any shocks until Epic releases his video. Epic is better than Consumer Reports.
Old May 18, 2017 | 11:55 AM
System's Avatar
System
Prolocutor
I thought you were bringing it to Cannes this weekend Epic?
Old May 18, 2017 | 12:09 PM
Rasty1's Avatar
Rasty1
Originally Posted by Karl4Cat
That's correct Mike. It's very easy to swap out the bushing and sleeve and that's the only difference between the 2005-2016 shocks and the yet to be released 2017 units. I was going to wait but Fox told me later in the year.
Well I will get them ordered, because I am not going to Rancho's again.
Old May 18, 2017 | 12:19 PM
System's Avatar
System
Prolocutor
The cheapest place to order the shocks is Auto Anything. Do an online chat with them and ask some random question like if they are in stock. When they say yes, ask if they have a coupon code to help you decide to make the order. They will likely give you a 10% code.
The only place to get the bushings and sleeves is Poly Performance. They don't have both parts online but if you call to order they can do it that way.
bushing- 2 each
014-11-002-A
sleeve- 2 each
213-28-007-B
Old May 18, 2017 | 12:20 PM
Rasty1's Avatar
Rasty1
Thanks for the tip!
Old May 18, 2017 | 12:28 PM
EpicCowlick's Avatar
EpicCowlick
bushing- 2 each
014-11-002-A
sleeve- 2 each
213-28-007-B
This ^^^. All you have to do is ask for the 10% off and they'll give it to you quick. Poly Performance may have a problem though as they have gone through these parts quickly and are having a hard time keeping them in stock.
Old May 18, 2017 | 12:37 PM
First3Quarter's Avatar
First3Quarter
I can add that the fox shocks do make an improvement. For me with the oem shocks, when I would be turning or going around a curve and hit a pot hole I would get a pretty good skip in the rear end. With the fox shock and the much quicker rebound, the skip is all but gone and mostly just a bounce now. As a bonus, less body roll and nose dive.
Old May 18, 2017 | 02:29 PM
F250Smitty's Avatar
F250Smitty
Is there different valving or adjustments with just the standard fox 2.0s? Or are they standard?
Old May 18, 2017 | 02:39 PM
System's Avatar
System
Prolocutor
Vendors like BDS do their own valving but I just went with the standard FOX valving. They are completely tunable if you have a shock guy to do it for you.
Old May 18, 2017 | 02:44 PM
wb6anp's Avatar
wb6anp
I'd hate to buy Fox if they are going to change the valving on them for the '17's
Old May 18, 2017 | 02:47 PM
System's Avatar
System
Prolocutor
You'd never notice if they did. The same shock part numbers go on anything from a short bed, 6.2, F250 all the way up to a F450. They are valved for a wide range of weights. It's a generic setup.
Old May 18, 2017 | 03:22 PM
wb6anp's Avatar
wb6anp
Ok 1 more question, is there any advantage to having the adjustable res on a truck that will probably will very rarely go offroad, bit I tow lightly.
Old May 18, 2017 | 03:27 PM
  #28
System's Avatar
System
Prolocutor
No to me. Lots of cycling will cause shock fade so the more fluid you have, the more resistant to fade. That said, I don't think on road towing applications would noticeably benefit from it. I asked FOX about it and even their tech admitted that it wouldn't help me much if at all. Adjustment would be fun for some but I know I'd never get under there and do it. I'm more of a set it and forget it guy. So, it's really up to you. It certainly won't hurt and could only help. Balance your priorities and needs vs. cost.
Old May 18, 2017 | 04:08 PM
  #29
First3Quarter
These are the shocks I draw my experience from. Overkill for just towing.
Wow. I had a long winded response that was lost to disconnect. But I tend to ramble so I will summarize.
In short, from experience I feel the fox 2.0 is valved properly for the weight of the super duty as is. The adjustable reservoir shock would only be beneficial in limited circumstances.
Last edited by First3Quarter; May 18, 2017 at 04:10 PM. Reason: Include pic from removed shocks.
Old May 18, 2017 | 04:30 PM
  #30
Tricon's Avatar
Tricon
I got the adjustables because I like to have a lot firmer compression in the rear when I'm towing. Eliminates any pourpising and really soaks up the concrete freeways when towing with a heavy tongue.
I make them pretty soft on road, then crank them down when I'm doing 70mph washboard roads down in baja. Its night and day difference in those circumstances, and worth way more than the $250 it cost me. But if you aren't doing much offroading, and don't care about making them firmer for towing, you totally dont need them.
You can always add them after the fact, but they are pretty expensive add on if you don't go that route when you initially order them. FYI.
