Trans Grinding?
Old May 13, 2017 | 08:30 AM
ashort430's Avatar
ashort430
Trans Grinding?
I'm getting a sound every now and then of what sounds like i'm running over rumble strips on the side of the highway. I'm guessing it's the trans grinding. Any thoughts?
Old May 13, 2017 | 09:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My first thought is that I don't know if you have a manual or an automatic transmission.
Old May 13, 2017 | 09:06 AM
ashort430's Avatar
ashort430
4 Speed auto. sorry
Old May 13, 2017 | 10:28 AM
crop harvester's Avatar
crop harvester
You will have to go through the process of elimination,inspect shake rattle spin test,front wheel bearings,brakes,drive line spline yoke & ujoints & carrier bearing,rear axle ,transmission tail shaft,[transfercase if its a 4x4 ] may need to put it up on jack stands & test the running gear, But be careful You dont get tangled up in moving parts,note sometimes you have to drop drive line to test u joints.
Old May 13, 2017 | 11:26 AM
ashort430's Avatar
ashort430
I think it's the trans because it seems to be happening when it upshifts and it stops when i let off the gas.
Old May 13, 2017 | 11:29 AM
coax9952's Avatar
coax9952
U-joints will do that too, and because you've got a bunch of them under there, all of them are suspect
Old May 13, 2017 | 12:11 PM
Walleye Hunter's Avatar
Walleye Hunter
I 2nd what coax says.
Old May 13, 2017 | 05:27 PM
Rikster-7700's Avatar
Rikster-7700
Definitely the cheaper and easier thing to check first before you start tearing into a tranny.....
Old May 14, 2017 | 01:45 PM
Steelheader87's Avatar
Steelheader87
Check your hub bearings, I had same symptoms, hit a bump and sounds like rumble strips. Slow down or stop and goes away until you hit another bump.
ford7872
May 14, 2016 09:50 AM
57Fitzjohn
Large Truck
16
Aug 15, 2014 12:06 PM
96MDL
Dec 30, 2010 09:10 AM
BURNSTOUGHFORD
1997 - 2003 F150
Aug 14, 2008 07:30 AM
Hsi95
Mar 31, 2004 11:54 AM
