Dumb Question: PTO VREF
Old May 13, 2017 | 01:10 AM
akblackfoot's Avatar
akblackfoot
OK so I've read on here that the PTO VREF wire is a 5v source and that what I need to wire my pressure sensors to for my fuel and coolant pressure. My stupid question is, when I find this wire, does it already have the 5V power going to it or does it need connected to something on the cab side of the firewall? I assume I will find it in the bundle of upfitter wires hanging on my firewall on the drivers side?
Old May 13, 2017 | 01:31 PM
Yahiko's Avatar
Yahiko
OOPS I was WRONG it is the Vref 5v
There is a Vref in the passenger compartment near the parking brake along with the PTO and BCP.
if you need a VRef that value will be 5v.
You can pull that off the IPR,EBP or a few
other places in the engine bay.
Have a look at this engine control PDF for
the VRef locations that you could tap into.
Watch out for loading. You don't want to pull
it down too far or you will have problems.
I thought that I had the high idle stuff but
right not can't find it. It has the PTO info.
I will post it when I find it.
Found the PTO and BCP connection info.
Old May 13, 2017 | 03:09 PM
Yahiko's Avatar
Yahiko
Nothing like a mistake to make your day.
I posted the updated files.
Also you should check this link.
https://www.fleet.ford.com/truckbbas/non-html/Q162.pdf
Here is the thread that link came from.
https://www.ford-trucks.com/forums/1...-idle-kit.html
Old May 13, 2017 | 04:42 PM
bismic's Avatar
bismic
I use 12v switched power for my fuel pressure and coolant pressure. Depends on the sensor.
Yahiko
Oct 9, 2016 11:47 AM
d450heavy
Sep 14, 2015 05:03 PM
Reverend Jim
Aug 16, 2015 08:08 AM
wejones
Mar 1, 2008 01:31 PM
amae11
1997 - 2003 F150
Jan 4, 2007 11:33 AM
