Sponsored by: Auxito
View Poll Results: Any help
Just point in the right direction
0%
anyone
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Electronic Coolant tempurature(ECT) sensor circuit
Old Jan 2, 2007 | 12:21 AM
amae11's Avatar
amae11
Unhappy Electronic Coolant tempurature(ECT) sensor circuit
Where is this located on a ford 2000 F-150 5.4 triton I need to replace??? (OBD-ll) is reading that its bad have a haynes manual. Can not figure out where it my be located (ECT)Electronic coolant temperture sensor circuit reading low input.Any help will be great soory if I sound DA Like just point me in the right direction thanxs for the help
Old Jan 3, 2007 | 02:58 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE amae. What DTC are you getting? Would it be P0117? I don't know exactly where it is located on your truck. I would look near the thermostat housing. Good luck.
Old Jan 4, 2007 | 09:00 AM
amae11's Avatar
amae11
KingRanchMan02 Yes Sir it read P0117 ill look around there, I did delete the code and engine light has not come back on.I was coming home from up north Michigan thats when e light came on. I checked oil while going over engine and it was realy realy almost could not read low but I run pur syn oil ? would that make that sensor come on do you think just running hot like that ???was running around 80 mph on cruise. Thanxs for the info ....PS Good looking pooch you got there. Amae11@hotmail.com
Old Jan 4, 2007 | 11:33 AM
KingRanchMan02
The DTC is for "low input" so, I don't think that it was running hot. What did the temp guage do when the light came on, do you remember?
Thanks, Rocky is his name. He is a little over 9 months old now and weighs in at 75 lbs and is still just a pup. I don't have a current picture of him right now.
