Installing turbine inlet v clamp is a biyotch!
I used bungee cords to keep the turbo and inlet together. In the end, I had some luck on my side to get the clamp on. Keep trying, you will get it.
If someone else is available to help, it may make things easier to have someone under the truck holding up/maneuvering the pipes/collector while you sit up top ready to tighten the clamp. Also, you made sure to leave the pipe to manifold connections very loose right? You'll need some "wiggle" room.
Easy. Put the clamp over the collector (slide it back up on the collector), then alight the turbo with the collector slide the clamp over and tighten it enough where the turbo doesn't come off the collector, then install the turbo to pedestal bolts (you will still have enough movement from the clamp to align the turbo and install the bolts) ones you get the bolts threaded some now you can tight up the clamp then the bolts. I should make a how to video to better explain what I'm saying lol..
That would be a great video!
I hooked a ratchet strap behind the turbo collector and put it through the passenger front tow hook. This held the collector loosely in place with enough tension on it so I could wiggle it around while standing near the driver's side. I felt the pin drop into place after a couple wiggles. Then I tightened the ratchet strap up some more and felt around the V-clamp until I was sure it was seated correctly. Then tightened it up. My turbo was bolted down. I don't trust my karma.
It doesn't hurt to put a little nickel based antisieze paste on the flanges and clamps before attempting to assemble-gives you a bit less friction when trying to move that heavy turbo around and into place. Just don't sniff the fumes after (of should I say if) the engine fires up. I usually put a small amount of that paste on the turbo mounting bolts too.
Funny enough, I just installed bellowed up pipes on mine yesterday. I had to sit back and take four breaks from it. I ended up removing the bolts from the manifold side of each up pipe and hooking a bungee up to the engine removal ring on top of the block. Sweet talking her the whole time trying to get her to work for me. Finally after two hours or so, the baby's butt was lined up and was able to get the clamp on it. I think the anti seize around the clamp helped big time. Good luck, I know your frustration level right now.
Shattered
08-02-2017 08:35 PM
