Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
E40D Speed Sensor VSS problem
Old May 9, 2017 | 12:55 AM
wyobuck's Avatar
wyobuck
Experienced typical speedsensor problems, loss of speedometer, dropped out of gear, limped home without overdrive. Pulled speed sensor and found gear drive damaged, very difficult to turn. Installed new sensor and gear drive, everything was beautiful, speedo was back, smooth shifts for about 50 miles, then same symptoms. Now stuck in KS trying to figure out ehy NEW sensor went bad so quickly? Any HELP would really be appreciated. 😢😢😢😢 Update, removed new sensor and found drive gear damaged again, but still spins freely.
Old May 9, 2017 | 09:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is this the speedo-gear type? It's possible the original trashed gear left crud in the gear teeth of the tranny shaft gear, or worse, the gear on the tranny shaft is shot.
Not sure if the tranny shaft gear is plastic or not.
Old May 9, 2017 | 10:29 AM
wyobuck's Avatar
wyobuck
​​​​​​​Thanks for the response, yes it is speedo gear type, it is mounted in the tail shaft housing, if the shaft is shot, can it be replaced by removing the housing?
Old May 9, 2017 | 12:22 PM
krewat's Avatar
krewat
You wouldn't need to replace the shaft. The speedometer "drive gear" just slips onto the shaft. Getting to it, you need to remove the tail shaft housing.
BUT - I've never worked on an E4OD, so please wait for someone else to answer before you delve into that - or get a shop manual somehow.
Old May 9, 2017 | 12:27 PM
wyobuck's Avatar
wyobuck
thankss
Yeah, i was able to get a look in there and can see the inside gear is also bad, got a replacement at a local dealer, gave me some encouragement so i am going in lol. Will post my results. Thanks again.
Old May 11, 2017 | 01:12 PM
wyobuck's Avatar
wyobuck
Gave up
Gave up, allen screws holding drive shaft were getting ready to strip, had to soak them in penetrating fluid.
Got the housing off and found a fried bearing. Need a puller to get inside collar of bearing off, then finally will be able to drive gear.
Old May 11, 2017 | 04:38 PM
krewat's Avatar
krewat
Wow, sorry to hear that, but we tried, eh?
Taking it to a tranny shop?
Old May 11, 2017 | 05:00 PM
wyobuck's Avatar
wyobuck
Nope just had to wait till the penetrating oil did its job. Now trying to get bearing out. Apparently this section does not get fluid from transmission, 4 oz has to be added in its own filler hole. If it leaks a little and runs dry, the heat will melt the drive and driven gears and eventually tear up bearing. Who knew, certainly not the previous owner of this rig, but i bet most owners dont know.
Old May 11, 2017 | 05:10 PM
krewat's Avatar
krewat
I guess this isn't a slip-yoke setup? It's the flange-type.
Again, never worked on an E4OD so in a way, I'm learning a lot from this thread
Old May 13, 2017 | 09:23 AM
wyobuck's Avatar
wyobuck
Great link from manual
http://www.thedieselstop.com/faq/9497faq/maint/96fman/stj65015.htm
Old May 15, 2017 | 09:27 AM
wyobuck's Avatar
wyobuck
Cheapest site I found for ZF Brake parts
I bought all parts for my rebuild for $150, Ford wanted $200 for 1 bearing.
https://www.allstategear.com/mobile/Category.aspx?id=1986
IntrstlarOvrdrve
Jan 17, 2015 11:37 PM
lciambotti
Dec 16, 2008 04:40 PM
MBBFord
1997 - 2003 F150
Apr 10, 2008 12:28 PM
cdherman
Oct 7, 2003 07:25 PM
Southern Fried
Feb 7, 2002 03:35 PM
