74 F-600 4x4 axles
74 F-600 4x4 axles
Hi, I bought this truck today at an online auction, so I have not seen it in person and do not have the ability to get any info off of tags that may be there, at this point; but I was wondering if anyone knows anything about the front drive axle on the truck. The only hub I know of that has a similar design are Colemans, but they don't really look like this. I've never seen anything else like it. Does anyone have info?
Look for a similar metal tag on the drive axles as the warranty plate. (When you have truck in possession). Rear looks like a Rockwell could be F106 or H140 model.
The front most 4wd converter manufacturers used a F106 center section and housing variation of with their ends attached.
D7TZ-16005-B .. Right Front Fender / Obsolete
No Ford dealer or obsolete parts vendor has any.
D7TZ-16006-B .. Left Front Fender / Obsolete
PREAUS MOTOR CO. in Farmerville LA has 1 = 318-368-3805.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 20 = 800-476-9653.
This truck was converted to 4WD by an aftermarket company, possibly Marmon-Harrington.
Originally Posted by T-700
VIN: F60DVT01994 / WB: 158 / COLOR: Blank* / TYPE/GVW: F602 / BODY: 4B8 / TRANS: A / AXLE: 66 / MAX GVW LBS: 19200 / DSO: 230753
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
T01994 = 1974.
158" Wheelbase.
F602 = F600 2WD (gas); 19,200 lbs. GVWR
4B8: 4B = Black Heavy Duty Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
66 = Rockwell model F106 Single Speed Rear Axle / 7.20-1 / 15,000 lbs. Rear Axle Capacity.
19,200 lbs. Gross Vehicle Weight Rating.
230753:
23 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from.
0753: Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color specified by the original purchaser, making it a Domestic Special Order.
Thanks for all the info Bill. That's interesting.
Guess people need to replace right front fenders more often. Should be going to pick up the truck next week sometime after the check clears. I'll see what I can find on the front axle. From the design it seems like if must be a Coleman. I don't think anyone else makes them like that.
Looks like other than the top of the cab, it's in great shape. You will probably find that it's been walked on and caved in. That causes the rear inner structure to pierce the outer skin, and water just pours in. I had to replace the top on my '78 F-7000 for the same reason.
Here is a link to the auction site, so everyone can see all of the pictures: https://www.purplewave.com/auction/170503/item/DA7768
Chuck
on
It just so happens that I have a MC 9,12,17 repair manual. From the warranty and replacement parts certificate I received with the manual I assume its pre 1975. So it should be right in your wheel house. I can make you a copy for whatever that cost is plus shipping. Send me a pm if you are interested. Nice truck by the way. Looks to me like you are missing the power yoke disc inspection covers. Probably no biggie. Should be easy to make or have made.
Mark
Mark
