Issues Questions
Just wondering if some of the issues I am seeing with my 6.0L are related, or just individual problems that need to be eventually addressed.
I have a 2003 F-350, with a March 2003 build date. I have the Scanguage II and monitor temps. I use normally use sysnthetic oil, with the Archoil additive. Oil is analyzed every other change for any signs of coolant, or other problems. So far, no issues. 145,000 miles. Everything is stock. I have been aggressive on oil change intervals, coolant flushing, and fuel-filter service.
When I'm running unloaded, my deltas are in the 7-11 degree range. For instance, today I noted 177/188, 184/189, 181/193 at different times, cruising from 45-75 mph. Ambient 60 degrees. At idle, when starting, temps vary by 1-2 degrees. I was towing a 9,000# trailer this weekend, and saw 14-15 degree deltas @ 45 degrees ambient.
I do have hard-start issues. The truck needs to be plugged in to start without a fight. Used to be only in the coldest weather, but now it's most of the time. I'm running dino now, with no Archoil, as the oil pan needed to be replaced. I wanted to make sure that issue was resolved before going back to the synthetic.
The truck is going in to have the glow-plug system and injectors checked. If I need to have significant work done, I am thinking about doing the flush program, and just doing the oil cooler at the same time- if you think the pattern above is developing into a problem.
I'm not in a position of replacing this truck, and I am willing to put work and money into it to keep it running well. It's not a daily driver (other than hunting seasons). It's a tow vehicle for (2) horse trailers, and an RV camper. So, if it's running, it's working. If it's working, it needs to be reliable.
Just curious what you all think. I'm trying to put a plan together to address any potential issues. I'm pretty comfortable doing suspension, brakes, and some add-ons... Just leery of digging into the motor. But, it's not out of the question, if I can get my head wrapped around the issues. Thank you for any thoughts, I really enjoy reading the responses to the questions. Amazing knowledge base here. Thank you,
Don
Replace both plugs and harness.
15° separation is approaching the limit and oil cooler replacement is in your future, sooner than later is a good plan... OEM only.
Hard start: if plugging in makes that big a difference especially now that it's not super cold all the time, I'd check the FICM out. You ScanGuage can do all three voltages, so make sure it's getting fed correctly and running at 48V. I would strongly suspect the FICM even without hearing your voltages just based on you having to replace the oil pan. After 14 years, there's a very good chance your wiring is starting to get corroded and your grounds likely aren't very good or might even be rusting on the frame, so the cables in the starting/charging system might just need a good once over with some steel wool to get everything back to how it originally was.
FICM issues almost always stem from electrical issues, which means check the batteries, the alternator, and your wiring. Jack did a great video on the electrical system here:
https://www.ford-trucks.com/forums/1...tery-life.html
FICM main power is monitored on the main screen with ECT/EOT, and shows 48.5 under most environments. I will check to see what other FICM readings it offers... What should I be looking at, and what ranges identify a problem?
The thermostat issue is a new one on me. I'll do a forum search... Thanks for the tips!
Don
When you don't plug in what happens?
When cold start, it take 4 or 5 tries to get the truck to fire enough to keep running. It seems to only fire on a couple of cylinders, sputters, kicks, belches black smoke (rich) and then dies. If you feather the throttle up to 1200-1500 rpm for 30 seconds or so, it will settle down and keep running- and then warm up as normal.
Leave it plugged in, and it starts just fine. All of this is at 45 degrees or warmer.
If three plugs are out, she'll barely fire. Compression builds heat, heat fires the cylinder so let it compress a few cylinders full of fuel and it will start.
The couple glow plugs that actually are working, your heating so hot, the tips may melt off and drop into the cylinder. Think you have problems now? And plugging in pretty much confirms the issue. Once the cylinders are at around 60°, they fire easily and the block heater gets them near 120°
If you dcam the truck for codes, it comes back zero found, it the counter will show the stored codes. Then get a real reader and read them to diagnose the issue.
You can visit the scan gauge web site to find the x gauge codes or even search the forum, someone has posted them somewhere.
