Need help with turbo
I just started using this old cell phone as a display so it's not got ICPV and a couple other PIDs programmed yet, I just threw it on yesterday.
Are the VGT duty cycle readings changing at COLD idle or HOT idle?
TSB 09-24-03 (cycling the turbo) talks about a false P0470 code.
https://www.ford-trucks.com/forums/9...-for-6-0s.html
P0470 can cause a MAP/BARO correlation code, P0069 I believe.
If anything is wrong with the sensors, I would suspect the EBP before the MAP or Baro (from what you have posted). If you suspect the EBP, just drive with it disconnected for a while.
Maybe the vanes are sticking in the turbo? Has it been cleaned, etc recently?
Edit -
If you are having VGT problems, they should settle down w/ the EBP unplugged.
If you end up needing a new VGT actuator, I am a fan of the OEM one (Ford part #5C3Z-6F089-BA for $260), but Garrett makes one that people are using - part #792593-0001 for $160 at RiffRaff.
VGT solenoid replacment instructions??? - Page 2 - TheDieselGarage.com
"CAUTION: The VGT actuator valve is sensitive to contamination. All work areas must be clean before starting this procedure. Do not allow contamination to enter the valve ports, cam follower, or turbocharger housing. Handle the VGT actuator by the solenoid body only. Do not attempt to wipe oil off the valve. Do not let the valve come in contact with materials that could contaminate the valve mechanism.
CAUTION: Use only the Carburetor Tune-Up Cleaner PM-2 to spray the actuator valve. Brake cleaner or other solvents may damage the actuator valve.
Be careful when you clean it. But check the oil supply tube. The old one is the stainless braided center section. The new one is the solid tube."
VGT Tests (Test 1 is w/ IDS):
Test 2
• Raise engine speed to 3500RPM and hold it at that point while monitoring EBP_G and MGP.
• EBP_G should be between 5 and 13 psi and MGP should be between 2 and 6 psi.
• If MGP and EBP_G are both high, disconnect the VGT control valve electrically and rerun the
test.
• If MGP and EBP_G change inspect the wiring harness and connections.
• If MGP and EBP_G do not change (lower) when VGTCV is disconnected remove the valve
from the turbo, being careful to handle the valve by its solenoid body only, and plug it into the
engine harness.
• Then apply pressure to the cam follower (tip of the valve) with your thumb while actuating the
valve with the WDS and look for movement.
• If the valve moves then proceed with Test 3, If the valve does not move replace the valve.
• The VGTCV (base part # 6F089) can be tested electrically, measure the resistance of the
actuator coil using a DVOM, the resistance should be between 3.42 & 4.18 ohms @ 73°F
EOT. If the engine is hot the resistance should be between 4.4 to 5.3 ohms @ 200°F EOT.
No-Load Boost Pressure Test
RPM..........VGTDC#............EBP_G............MG P
Idle...........60-82%............0-6 psi..........0-1 psi
WOT..........30-45%...........4-18 psi........2-9 psi
