Anybody know part number for external harness that goes to transmission... 2003 model. Auto. Screw broke on passenger side plug in. Snug is to much apparently.
I do know they changed the fuel pump wiring. Put a late model Trans harness on and spend 3 hours running pinouts. Oh wait,, that was me. Lol. Customer supplied parts mostly ends unfavorable.
Trying to track it down, FordParts.com came up w/ this meassage:
Due to low demand, Ford Motor Company is no longer manufacturing the following part(s) you selected. Please contact your FordParts.com dealer with questions.
Highly suggest you take the advice above.
Edit - also has this note:
NOTE: re-use original bolt that retains connector to transmission, or order new bolt 3C3Z-14A187-AA
Lastly, if all you are concerned about is the transmission connector, I would think that you should be able to get any harness and use that individual connector.
