Sponsored by: Real Truck
Shock bolt torque specs
Old Apr 28, 2017 | 07:23 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
I am replacing the front and rear shocks along with the steering stabilizer. I can't find a tourqe spec for the bolts. I search all over and get different specs. Can anyone help?
Old Apr 28, 2017 | 07:24 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
In general with bolts like these you tighten until the bushing swells. The torque isn't critical because the fastener isn't clamping anything, the load is a shear stress on the body of the fastener, not acting against the clamping force.
Anyhoo.
Front upper (stud): 46 lb-ft
Front lower: 111 lb-ft
Rear upper: 46 lb-ft
Rear lower: 66 lb-ft
Stabilizer upper (drag link): 67 lb-ft
Stabilizer lower (bracket): 26 lb-ft
Have you already taken the old ones out? I usually split the nut off the stud on the front with a chisel, they way they rust on there cutting or splitting the nut off is a real time saver.
Old Apr 28, 2017 | 08:05 PM
SUPERDUTY_08
I did the rear shocks earlier. Tightened them up to 50lbs. I'll do the others on Sunday when I have time.
Old May 22, 2017 | 12:24 PM
SUPERDUTY_08
Bilstein front shock bushing compression
So I finally got around to changing the front shocks yesterday. I put on Bilstein 4600's, and attempted to follow their tourqe specs of 34 ft lbs. But I got concerned when I was tightening the tip not that the bushings where being compressed to much. So I backed off going any tighter. Can I get your thoughts on how tight the nut should be and how compressed the tip bushings should be?
Old May 22, 2017 | 06:23 PM
fordman19762003's Avatar
fordman19762003
The bushings are meant to be compressed quite a bit so torque the nuts down to the spec that is called for.
Old May 23, 2017 | 10:39 AM
SUPERDUTY_08
they started to look like a pancake. Is that normal?
Old May 23, 2017 | 11:01 PM
Yahiko's Avatar
Yahiko
You may want to have the torque wrench checked. The do go out of calibration
or even fail. There are simple ways to check the cal and more involved ways.
Here is a quick and easy one.
Old May 24, 2017 | 08:24 AM
texastech_diesel
Token Redneck
If the shock doesn't clunk, it's fine.
I've never seen a shock bushing rot before the shock is blown, and even if it does it's a $4 part for a universal bushing.
Old May 25, 2017 | 02:13 PM
droldsmorland's Avatar
droldsmorland
How do you know the beam wrench is accurate? Ive seen beams with permanently bent beams. I'd trust the higher end click or dial style over the beam. I have my clicks caled annually. I have to. I always ask the NiST guy how much he had to adjust them. Most of the time a pound or two at most on the lb/ft wrenches. They maintain accuracy pretty good IMO...Ought to for the $$$...Snap Ons
Old May 25, 2017 | 02:51 PM
Tedster9's Avatar
Tedster9
If the torque specs aren't a misprint, can't really go wrong following them. Careful not to confuse in/lbs with ft/lbs... And use common sense, a 1/4" bolt won't take 75 ft/lbs
swoosh1958
Oct 30, 2017 12:46 AM
Justin Jones
Jun 11, 2016 01:57 PM
99ExpyProblems
Sep 17, 2013 09:35 PM
forrester
May 4, 2006 09:43 PM
dgpruitt
Feb 8, 2004 11:02 PM
