Sponsored by: Kumho
Shock Bolts - Torque Specs?
Old Feb 7, 2004 | 07:44 PM
dgpruitt's Avatar
dgpruitt
Question Shock Bolts - Torque Specs?
I'm installing new shocks on a '90 F-250 4x4. This will be my first shock installation, and I was wondering how much torque I should put on the shock bolts when I install them?
(I have service manuals coming in the mail, but I'd like to get the shocks on now while it's not snowing)
Thanks.
Old Feb 7, 2004 | 08:45 PM
natewoz's Avatar
natewoz
60ft/lbs is about good. Torque on shocks is not nearly as important at some other things like ball joints, axle nuts, and engine/tranny parts. I usually tighten them till they feel good and snug with a 3/8 or 1/2 rachet. Kinda the human torque wrench approach. It's also hard to break 7/16" bolts without power tools, so overtightening isn't going to cause much for problems.
Being in NM as you are, you probably don't have fight the rust like we do up here in the Dairy State. But if there is rust, be ready to employ the hot wrench or grinder because the metal sleeves inside the shock bushings love to rust to the bolts.
Have fun with your project!
Old Feb 8, 2004 | 06:20 PM
dgpruitt's Avatar
dgpruitt
Thanks. I installed them this afternoon. The truck rides much better with the new shocks. I didn't bother with the torque wrench... just tightened them up "real good".
Old Feb 8, 2004 | 11:02 PM
rebocardo's Avatar
rebocardo
Usually the factory specs are 15 foot pounds on the top (if it is the spindle type, example BII) and 40-50 on the lower bolt.
mechelement
13
Feb 13, 2022 11:52 AM
WayneinChatham
1997 - 2003 F150
Aug 29, 2012 02:17 PM
Morning Wood
May 2, 2011 12:43 PM
FireTail-AR
Jan 7, 2007 07:10 AM
RyanMiller
Aug 25, 2005 04:59 PM
