1981 F-100 - Issues and Input!
Old May 20, 2017 | 03:43 PM
  #91
neoniacin's Avatar
neoniacin
Originally Posted by Ford F834
Are you staying with the 80/81 slide locks inside?
For now I am. Think I'll try the ones from bronco graveyard.
Old May 23, 2017 | 11:21 AM
  #92
1986F150six's Avatar
1986F150six
This thread is a little old and you said the driver's side was the one which was so bad, but then in the last post, you said you think you will try the "ones" from Bronco Graveyard. Well, if you are thinking of replacing both, I located a NOS [actually 3] right side with a great price from an unexpected source [UHAUL Tech Center / eBay store]. The freight is very reasonable, too.
E1TZ1023942A9A 81 FORD F100-350 RIGHT DOOR TRIM PANEL | eBay
Old May 23, 2017 | 12:05 PM
  #93
neoniacin's Avatar
neoniacin
Door panels are on the list. I haven't had time to do much lately. Work has kept me busy.
Will update next time I get time. Maybe this weekend.
Old May 23, 2017 | 06:13 PM
  #94
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
.....I located a NOS [actually 3] right side with a great price from an unexpected source [UHAUL Tech Center / eBay store]. The freight is very reasonable, too.
E1TZ1023942A9A 81 FORD F100-350 RIGHT DOOR TRIM PANEL eBay
I LOVE U-techcenter!
That place is great, and they have NOS going back to the '70's
It's pretty a amazing that this stuff has been warehoused for so long after they've retired generations from their fleet.
Old May 25, 2017 | 07:54 AM
  #95
neoniacin's Avatar
neoniacin
I had a little time and I got my inspection plate cleaned up. No leaks!
The old gasket came off in little pieces.
Old May 25, 2017 | 08:04 AM
  #96
Gary Lewis's Avatar
Gary Lewis
Another layer down!
Old May 26, 2017 | 07:00 AM
  #97
CountryBumkin's Avatar
CountryBumkin
I would get a spark plug terminal "crimper tool" and some new terminal ends, and redo/shorten all those spark plug wires. Or a properly fitted plug wire set...
I'm OCD when it comes to stuff like that under the hood.
It's lookin' good. Good luck
Old May 26, 2017 | 07:10 AM
  #98
Gary Lewis's Avatar
Gary Lewis
Mike - Good point. The extra-long wires are an invitation to miss-fires. For instance, the one that looks like it is laying on the steering shaft will abraid and short out there.
And, while you are at it, buy some vacuum hose and replace those to the air cleaner. The long one coming from a vacuum source and going to the temp sensor should be shortened. From the temp sensor the one with a plug should go to the cold weather module where the hose with no plug is. And the one on the cold weather module with a bolt goes to the vacuum motor in the snorkel.
Old May 26, 2017 | 10:36 AM
  #99
neoniacin's Avatar
neoniacin
I totally agree! I have lots of cable management to do. Not just plug wires either.
Yea the vacuum lines are on my list already. I have quite a few that are just plugged up.
On another note.... is there any downside to removing the smog pump and all associated hoses and brackets? It isn't hooked up and is just plain in the way.
Old May 26, 2017 | 06:02 PM
  #100
Gary Lewis's Avatar
Gary Lewis
No downside to removing the smog pump if it isn't being used.
Old May 27, 2017 | 01:57 AM
  #101
neoniacin's Avatar
neoniacin
Well, I removed the smog pump. Do I need to plug up where the hose from the smog pump attached to the carb or does it matter?
Started on the vacuum system. So many plugged hoses! Pics tomorrow. I will need validation everything is hooked up right.
Old May 27, 2017 | 07:35 AM
  #102
Gary Lewis's Avatar
Gary Lewis
The smog pump attached to the carb? Can you show us a pic of that?
As for the vacuum lines, here are my thoughts on the bare minimum needed: Vacuum Systems - ???Gary's Garagemahal.
Old May 27, 2017 | 07:44 AM
  #103
neoniacin's Avatar
neoniacin
Old May 27, 2017 | 07:48 AM
  #104
Gary Lewis's Avatar
Gary Lewis
Ahhh! The little fitting in the bottom pic is for vacuum to operate that valve. I don't think it went directly to the carb because it should have been controlled by some logic system to determine when to operate. In any event, it can be plugged.
Old May 27, 2017 | 09:41 AM
  #105
neoniacin's Avatar
neoniacin
The big guy in the first pic is what the big hose on the pump attached to. I cut the end off the hose and plugged it. Seems to run fine.
