1981 F-100 - Issues and Input!
Old Apr 26, 2017 | 10:27 AM
neoniacin's Avatar
neoniacin
Originally Posted by rednecksinc
maybe run some seafoam through the intake just to clean out years of carbon
I've heard of this stuff but I have not used it. I'll have to do research on it.
Anyone have thoughts on this stuff?
Old Apr 26, 2017 | 10:31 AM
reamer's Avatar
reamer
Just grab a whole column from a bone yard. Very easy to remove. Take off plastic pieces around column, remove two big bolts anchoring column to dash frame, unbolt 5 or 6 screws at firewall, disconnect harness, under hood, disconnect auto shifter lever, and steering column shaft.
Pull out and done.
Old Apr 26, 2017 | 12:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E4TZ-3511-B .. Upper Steering Column Flange / Obsolete
1980/89 F100/350 & Bronco with A/T and fixed steering wheel.
MUSTANG SERVICE CENTER in North Hollywood CA has 1 = 818-765-9266.
Old Apr 26, 2017 | 12:58 PM
FuzzFace2's Avatar
FuzzFace2
Pull out and done.
That's what I would do and save on shipping.
Dave - - - -
Old Apr 26, 2017 | 01:02 PM
FuzzFace2's Avatar
FuzzFace2
I have used it in a chipper/shredder that sat for years.
After a carb rebuild it still did not run right used half a can in the tank and about half a tank later was running like new.
Also used a can in my 02 Dodge Durango with close to 200 k on it to clean injection system and did help run better.
Dave - - -
Old Apr 26, 2017 | 04:34 PM
neoniacin's Avatar
neoniacin
Looks like seafoam has pretty good reviews. I'll give it a try.
Old Apr 27, 2017 | 10:32 PM
neoniacin's Avatar
neoniacin
So I called Mustang Service Center and he wanted $225 for it. That was more than I was willing to pay.
I ended up finding all those pieces to fix the column on E-bay for about $90. Should be here Wednesday. I'll post pics once I install it.
Now on to the next adventure!
After closely inspecting everything here is an updated list of things that need attention:
1. Transmission pan gasket leaking.
2. Linkage on the transmission was not connected. (missing hardware)
Goes up to the engine somewhere... Will need to trace where it goes.
3. Multiple hoses needs to be replaced. All kinds of vacuum lines are missing or plugged. How much do I need to hook back up?
4. More missing parts!
Old Apr 27, 2017 | 10:35 PM
neoniacin's Avatar
neoniacin
5. Rotors have some nasty grooves in them as well as some shielding issues.
That's all for tonight! Will continue inspection this weekend. I've decided to keep this as a diary of my adventure. Stay tuned!
Old Apr 27, 2017 | 10:47 PM
Gary Lewis's Avatar
Gary Lewis
The transmission pan seems odd. I don't remember an auto tranny with a connection to the pan.
The transmission linkage probably goes to the carb and is the kickdown linkage. It needs a C-clip to hold it in the lever, but it isn't too important as you can pull the lever into 2nd if you need to downshift.
The hose looks to be to the fuel pump, and that's a must-fix.
The ducting missing from the air cleaner is good to have to get cool air to the carb, but isn't a requirement.
The brake rotor looks bad, but the shield can be done away with if it is a problem. Or just leave it as is.
Old Apr 27, 2017 | 10:58 PM
neoniacin's Avatar
neoniacin
That's the transmission dipstick tube.
Old Apr 28, 2017 | 03:57 PM
FuzzFace2's Avatar
FuzzFace2
[QUOTE=Gary Lewis;17149168]The transmission pan seems odd. I don't remember an auto tranny with a connection to the pan. As posted below dip stick
The transmission linkage probably goes to the carb and is the kickdown linkage. It needs a C-clip to hold it in the lever, but it isn't too important as you can pull the lever into 2nd if you need to downshift. Yep
The hose looks to be to the fuel pump, and that's a must-fix. YES and I would doo ALL the rubber fuel lines. You should have ones by the tank(s) to metal lines, that one from metal line to pump and may have one or two by carb.
Only vacuum line I say you need is from carb to dist. for vacuum advance.
The ducting missing from the air cleaner is good to have to get cool air to the carb, but isn't a requirement. True but he is also missing the hot air tube that may be needed in cold weather.
The brake rotor looks bad, but the shield can be done away with if it is a problem. Or just leave it as is. True I have a car or 2 that I did a drum to disc swap and cant get the dust shields for. [/QUOTE]
Yes would that be for a C4 auto? I don't remember any C6 having that.
The old BW autos used in AMC cars used the same type of tube/stick set up.
Dave ----
Old Apr 28, 2017 | 04:21 PM
neoniacin's Avatar
neoniacin
Dave ----
Yes it is a C4 auto from everything I have found on it.
Old Apr 28, 2017 | 04:29 PM
  #28
NumberDummy
When I spoke with Bo, I told him that he had the only E4TZ-3511-B flange available NOS
You might call him back, offer him 100 bucks. The thing is, will a used column that you buy...be any better? It could be worse.
1981 F100 300 I-6 & 255 or 302 V8 could have either a C4 or C6. C4 has 11 trans pan bolt holes, C6 has 17.
These 3 engines were all that were available.
Old Apr 28, 2017 | 10:49 PM
  #29
neoniacin's Avatar
neoniacin
I didn't buy a used column
Here's what I bought:
Said it was liquidation of old parts stock. It was $60. I'll have to clean it up and paint it. The other $30 was for the other parts suggested and shipping.
All and all not too shabby!
Old Apr 28, 2017 | 11:46 PM
  #30
kr98664's Avatar
kr98664
Hey! No name calling!
