TorqShift-G 6R100 Temperature
Old Apr 24, 2017 | 06:39 AM
69cj's Avatar
69cj
Originally Posted by BII Plow Truck
Swap-out the oem fluid with Amsoil and you'll see temps drop.....I saw temps drop in my A4LD Bronco II while plowing. I was thoroughly impressed to say the least! (Yep, I installed a temperature gauge as I was concerned while pushing snow with a known weak transmission).
The torque shift tranny has an internal t-stat. Changing the fluid will do nothing for the temps. It could possibly screw with you warranty if it's not an approved substitute.
Old Apr 24, 2017 | 06:50 AM
troverman's Avatar
troverman
I agree. The fluid temperature is ultimately controlled by the transmission fluid cooler, located under the radiator on 2017 diesel models. The brand of fluid would not have much to do with it.
Old Apr 24, 2017 | 06:54 AM
peoples1234's Avatar
peoples1234
1900 miles pulling a TT, highest I saw was 205.
Old Apr 24, 2017 | 07:06 AM
Tom's Avatar
Tom
No, that's incorrect information that could wreck the OP's transmission and won't do a thing about his temperatures. Every transmission used in a Super Duty since '05 has had an internal thermostat that regulates temperature. Nothing you put in the transmission pan is going to run any cooler, because the setpoint of the transmission thermostat will remain the same. An improper fluid can destroy the transmission.
The OP just needs to understand that these aren't his granddaddy's transmissions, and they're designed and controlled to run hotter than the autoboxes of yore. Nothing short of complete disassembly and the installation of aftermarket parts, which would result in a transmission that's less reliable.
Old Apr 24, 2017 | 08:18 AM
h20camper's Avatar
h20camper
Thanks Peoples1234
drh1175
2009 - 2014 F150
17
Jul 12, 2024 12:48 AM
Mickey Bitsko
1997 - 2003 F150
Apr 13, 2018 12:09 PM
danr1707
Mar 9, 2018 11:39 AM
ssunit1
All Things Towing
19
Feb 3, 2016 07:08 AM
onesr
Jul 27, 2007 08:20 AM
