IMO fordpass is worthless (for superdutys) - it does little or nothing.
FordPass is a connection to the dealer (for calling, or scheduling)
IT provides a connection to ford credit (singular or automated payment setup)
and it among other stuff it provides fuel pricing (ala gas buddy).
it does NOTHING to connect or automated our superduties - in a nutshell, you don't even really need to install it (its not integrated to anything).
IF you have the add-on perimeter alarm and remote module -
Ford REMOTE ACCESS is your connection to the vehicle for lock/unlock, engine start/stop and alarm triggers.
FordPass on my 17 F150 is far from worthless. I can remotely start/stop it from anywhere in the world that has cell phone access. I can also unlock/lock it. I can also schedule start times. If someone steals my truck I can look on the map and know exactly where its at. At the moment I can check the fuel level. I understand that in the next five years more features will be added. For the next five years the service is free.
IF you'll notice, I said -
Originally Posted by bushpilot
fordpass is worthless for SUPERDUTY's
I understand that FordPass provides better value on the F150 - but this is the 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab FORUM
your comparison of what FordPass can do is inaccurate for this forum.
Unlimited data (de-prioritized after 22GB) for $20/month. It's awesome, and you can buy an A/C adapter so you can take it with you. We take it and put it in our RV when camping.
OR get one of the cellular/mobile USB (chargeable) hotspots (you can use anywhere, not just in the car/truck)....or TETHER you smartphone as a solution.
It will at least do for the SD what it does for the F150 when its available. So as I said its far from worthless and its free
This looks very interesting. I've used several different hotspots and the drawbacks have always been that they don't "smart-charge" - they're only smart enough to display that they're fully charged and should be disconnected power - and they overheat and shutdown at temperatures far below what the inside of a vehicle sees on even a moderately warm day.
I wouldn't want to occupy the OBD port with this, but it appears to get only power from the port, so that should be easy to overcome.
Agreed. I bought (I could have made but didn't want to take the time) an adapter that plugs into a regular outlet and has an ODB connector for the Mobley device to plug into. I just plug it into the AC outlet in the truck, in our RV, and actually use it at home to give me dual WAN support on my router. I'm a tech geek so I like gadgets.
I just tried to by a Mobley and AT&T is out of stock. Keep us posted on how yours works.
