EGR Valve question
Old Apr 22, 2017 | 12:27 PM
Watcher58's Avatar
Watcher58
EGR Valve question
I'm not throwing codes or anything but like to stay ahead on maintenance on my vehicle. I've had the 04 6 L about a year now and have thought I should service or replace the EGR valve. A new valve sounded better in my head but they are $200. Is this another piece of hardware which should remain a Motorcraft only part or are there acceptable aftermarket parts?
Thamks
Old Apr 22, 2017 | 01:03 PM
bismic's Avatar
bismic
I would stay w/ Motorcraft on it, but I probably wouldn't replace it if there was no indication of a problem.
Old Apr 22, 2017 | 01:05 PM
Watcher58's Avatar
Watcher58
Is cleaning a good option with a new o ring kit?
Old Apr 22, 2017 | 01:14 PM
bismic's Avatar
bismic
Wouldn't hurt to pull and inspect ... and clean if needed. I used to do that each year and then got lazy. Mine has always been oily and also oily in the intake manifold - even w/ the ccv filter. The EGR valve will come out a little easier if removed when hot (but they can be pretty hot, so wear gloves).
Just be careful in cleaning. Use Carb cleaner to clean the gunk off (not brake cleaner) and don't get the cleaner into the solenoid.
Most people fill a cup w/ carb cleaner and suspend the bottom part of the valve in the liquid (keeping the liquid level just below the solenoid body). Then brush the junk away and rinse. Afterwards, make sure the valve moves up and down and the spring return feels fairly strong.
Old Apr 23, 2017 | 06:31 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yes it is. Like Mark said use carb cleaner and keep the valve in the upright (as installed position) while cleaning, but they polish up nicely. There's a good thread in the teach folder about how to get it out without jacking up the ears on the valve; it's a straight forward 1 hour job for you take your time and really get it clean.
Old Apr 26, 2017 | 07:32 AM
Watcher58's Avatar
Watcher58
Thanks gguys...anouther task added to the list
tonefordays
Jul 6, 2013 07:27 PM
pmoney1983
Aug 20, 2012 07:03 AM
mickpowell1967
Aug 11, 2009 08:43 PM
Northriver
Feb 11, 2009 05:13 PM
92 f-150
Jul 1, 2008 06:55 PM
