06 expidition question
Old Apr 18, 2017 | 12:01 PM
shaggyb00m's Avatar
shaggyb00m
My wife has a 2006 ford expidition.... 3v 5.4. So her AC in the front doesn't blow cold air it will blow warm to hot air but the back blows cold air. The heat in the front works fine just the AC.. I tried a AC recharge but nothing..
Suggestions?
Old Apr 18, 2017 | 03:45 PM
lincolnshibuya's Avatar
lincolnshibuya
your temperature blend door might be bad, it's stuck in warm/hot position. what kind of controls you have? auto or manual? If it's an auto run the self-diagnostic check to show what failed.
the other possible issue might be a broken heater valve that didn't close and letting warm coolant go to your heater.
https://www.facebook.com/diyLincolnNavigator/
Old Apr 18, 2017 | 05:35 PM
shaggyb00m's Avatar
shaggyb00m
Coolant looks good. I changed the blower motor and the little blend control deal a month ago it's manual ***** to change temp.
Old Apr 18, 2017 | 07:19 PM
shaggyb00m's Avatar
shaggyb00m
So the other day the serp belt broke and I found this just laying around font know where it goes suggestions?
Old Apr 18, 2017 | 08:07 PM
lv2race's Avatar
lv2race
Not knowing anything about an '06, but looking at this pic, I'm guessing that is a vacuum line that connects to the nipple on the black control valve on the heater hose which may activate the hot water to travel where it needs to go?
Old Apr 18, 2017 | 08:08 PM
shaggyb00m's Avatar
shaggyb00m
Ya forgot to update this I plugged that into the nipple on the port right side of picture now everything works lol feel like an idiot. Thanks
Old Apr 19, 2017 | 04:32 PM
rla2005's Avatar
rla2005
Both of my Navigators had that vacuum line unplugged when I purchased them. The first was an '05, now I have a black '06.
Old Apr 20, 2017 | 09:04 AM
alloro's Avatar
alloro
Feeling like an idiot sure beats feeling hot with the A/C on. At least you fixed it for free.
Jerdub
Aug 2, 2016 02:46 PM
scottsman87
Aug 20, 2014 10:45 AM
rsm1012
Apr 26, 2006 01:10 PM
smarsh1966
Aug 6, 2004 03:14 PM
B2Guy
Bronco II
Oct 25, 2001 10:01 AM
