Pre fill oil filter?
Old Apr 26, 2017 | 07:03 AM
  #46
troverman's Avatar
troverman
Originally Posted by BII Plow Truck
I don't know why this is even being debated. Pre-Fill, period.
-It costs nothing to do
-It takes no more time to do (what's the difference if you pour the quart into the valve cover, or into the oil filter?)
-It pre-soaks the paper element inside for less chance of ripping causing some unfiltered oil to get by
-It ensures full oil pressure at start-up
-Ford denies warranty for using the incorrect oil filter without an anti-drainback valve causing dry starts until the oil fills the oil filter and then oil pressure builds.....so they will certainly deny warranty for not filling the oil filter during an oil change. They'll pull the ECU data and prove it to you that you ran it without oil, even if it was only a few seconds. It's all recorded, they're not dumb.
Its fine either way. I like the idea of prefilling better. Just FYI, prefilling does not ensure full oil pressure at startup. It still takes a second, because you cannot totally fill the filter, and oil is not held in the sprayers for the valve rockers. Your allegation regarding Ford voiding warranty for oil filters that aren't prefilled is completely absurd and not true.
Old Apr 26, 2017 | 03:48 PM
  #47
cappa's Avatar
cappa
I have to agree with the guy, what's absurd is not putting a little bit of oil in the filter when it sits straight up and down. Takes no time, definitely isn't any harder on your truck getting oil flow a couple seconds earlier, and why would they have an anti drain valve on the filter if it wasn't important to keep it full. Is your truck going to blow up if you don't, probably not but it definitely doesn't hurt and takes no time to put some oil in the filter while you let the pan finish draining.
Old Apr 26, 2017 | 06:54 PM
  #48
zeroo's Avatar
zeroo
Nothing like a good old oil thread. I change my oil about every month and a half and prefilling is a step I would never do. There is zero data that says it harms your engine to not pre fill, ford doesn't even recommend it. Your engine is prelubed, there is oil in rings and bearings. 2 seconds will not hurt anything. Would like to know gpm of oil pump at idle.
Old Apr 26, 2017 | 08:05 PM
  #49
maxfam's Avatar
maxfam
I prefill my filter. It makes "me" feel good.
Old Apr 26, 2017 | 08:22 PM
  #50
zeroo's Avatar
zeroo
And that is the absolute reason to do it. Nothing wrong with that.
Posting that not prefilling does any measurable damage to an engine without any evidence is absurd.
Old Apr 27, 2017 | 09:28 AM
  #51
cappa's Avatar
cappa
This thread is absurd. Especial 4 pages, it makes me feel good to pre fill. Do what you feel helps you sleep at night
Old Apr 27, 2017 | 04:23 PM
  #52
82_F100_300Six's Avatar
82_F100_300Six
All this reasoning goes out the window when you think how many engines have sideways oil filters...300 six....4.6......
Old Apr 27, 2017 | 04:27 PM
  #53
69cj's Avatar
69cj
That's what happens when trying to redesign the wheel.
Old Apr 27, 2017 | 10:49 PM
  #54
fordmantpw's Avatar
fordmantpw
I just let the dealer change the oil.
AHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
It's amazing what some guys obsess over. I thought I was bad!
Old May 12, 2017 | 05:12 PM
  #55
PwerStroke99's Avatar
PwerStroke99
I have always prefilled my filters on my 7.3 and will continue to do so on my 6.7. It does hurt to do it, a little self insurance imo. and doesn't take a lot of extra time.
Redrockerstl55
Mar 29, 2020 12:56 PM
Readgriff
6.7L Power Stroke Diesel
24
Nov 13, 2017 08:48 PM
thumper869
20
Apr 6, 2009 08:20 PM
deepbass
1978 - 1996 Big Bronco
Jun 5, 2005 11:21 AM
eager_49
Oil & Lubrication
Jun 10, 2003 10:51 PM
